Could accretion on a neutron star’s poles cause the jets?
In summary, the conversation discusses the possibility of accreting material on a neutron star's poles causing fusion reactions and resulting in ultra-relativistic jets. There is debate about the source and location of the ultra-relativistic conditions, with some suggesting it could be at the core of the star. The conversation also mentions that jets are not yet fully understood and that the neutron star's crust is believed to be impenetrable.
  • #36
My info about URM or quark-gluon plasma or quark type matter was gleaned from various sources. Just google those terms and terms like "radiation pressure" and "ultra-relativistic pressure" and things like (rho)(c^2)/3 will pop up. If URM or other ultra-relativistic stuff briefly formed in a neutron star it would logically escape the star quickly or heat the star.
I probably shouldn't have brought up the possibility of a compact star that was a mixture of neutrons and URM regulating its radius, and am still formulating thoughts on that. Its probably too divergent from what might cause ultra-relativistic jets from a neutron star.
Astronomy news on Phys.org
  • #37
Although I consider it implausible that massive particles could escape from the surface of a neutron star, electromagnetic radiation can escape, in particular X-rays. Note that infalling material seems to land preferentially at the magnetic poles (which are not generally aligned with the rotation axis, hence pulsars) and cause local high-temperature spots which emit strong X-rays.
I've not done any calculations, but I could speculate that perhaps intense X-rays from recently fallen material could push some of the following material away from the magnetic poles. This would mean that matter which ended up near the rotation axis as a result would be pushed in the same direction all the time as the magnetic poles rotated, creating a polar jet, whereas material in other directions would probably end being dispersed back towards the equatorial plane.
This might give a possible direction to explore for an explanation of jets, although I don't know whether enough information is available to check the viability, and that's a different idea from the current thread. Note that no similar explanation could apply for black holes, as there would be no radiation from the surface.
  • #38
Maybe the origin of powerful neutron star jets can be determined from observational analysis instead of mathematical analysis. (1) If all neutron stars with powerful jets have high spin rates also, that's a pretty good indication that spin rate (and hence a twisted magnetic field) is an important factor in powering (and not just directing) the jets. (2) If powerful jets from neutron stars sometimes don't occur simultaneously with accretion, that indicates the jets are not directly originating from the accretion.
  • #39
The snag with your statement (2) is that accretion isn't a single-stage process anyway, as I mentioned before. If a burst of stuff arrives in the vicinity, some of it may well produce immediate flares, but I think some of it can hang around in orbit as an accretion disk or rings for an extended period, only gradually working its way in over time.
Good luck with your investigations! If you find any relevant information in acceptable references, let us know, but to comply with the forum guidelines please try to limit any speculation to ideas which are firmly based on established science.
  • #40
An ultra-relativistic particle would easily escape. The escape velocity from a 2 solar mass, 12-km radius neutron star is only about 0.7(c)
  • #41
As I have pointed out before, you have failed to explain or provide any references as to what any such ultra-relativistic particle could be or by what physical means it could get enough additional kinetic energy when at or near the surface to escape. Please do not continue this speculation unless you can provide relevant acceptable references.
  • #42
IMHO:
In the very center of a neutron star,where mass is equal in all directions there should be an area of zero gravity.
This would allow circulation of particles in a small area of the core.
In-falling matter would disturb this area,causing great stress as the particles are forced into a different arrangement.
This stress would create a domino effect,focused by the magnetic field,causing the emission of energy from the surface.
  • #43
DrAupo1 said:
IMHO:
Although there is zero field at some point, this is essentially irrelevant, as the pressure is at a maximum at the same location.
The rest sounds like the sort of "techno-babble" used in Star Trek, and doesn't belong in Physics Forums.
  • #44
Yes, but could a large mass of accretion material build up around a neutron star for months without radiating, and then suddenly form an ultra-relativistic jet?
  • #45
Why do you have this fascination with the term "ultra-relativistic"? Surely merely "relativistic" is enough in this context.
I don't know how long accreting material can stay in orbit, but I wouldn't be surprised if some material could remain around for an extended period before its orbit became unstable for some reason.
Another problem I think I previously forgot to mention with your alternative idea about material being emitted from the magnetic poles is that the jets are along the spin axis, not from the magnetic pole.
You can find out a lot more about neutron star jets from Googling. I see that it is commonly assumed that neutron stars produce jets only when they have a relatively weak magnetic field. I just spotted a paper from some time ago (2003) explaining a specific possible mechanism: "FORMATION OF SEMIRELATIVISTIC JETS FROM MAGNETOSPHERES OF ACCRETING NEUTRON STARS: INJECTION OF HOT BUBBLES INTO A MAGNETIC TOWER", at http://iopscience.iop.org/article/10.1086/379752/pdf
  • #46
Why do you have this fascination with the term "ultra-relativistic"? Surely merely "relativistic" is enough in this context. I don't know how long accreting material can stay in orbit, but I wouldn't be surprised if some material could remain around for an extended period before its orbit became unstable for some reason. Another problem I think I previously forgot to mention with your alternative idea about material being emitted from the magnetic poles is that the jets are along the spin axis, not from the magnetic pole.
Ultra-relativistic velocities are much rarer and harder to achieve than relativistic velocities. If something is moving at >0.9c an explanation of how it could move at 0.1c is not satisfactory. If some material could remain around for an extended period, how would it be supported? If the magnetic field supported it, it should be radiating. Thanks for the interesting source ... I think it says the jets follow the spin axis of the disk ... isn't this the magnetic axis of the star?
  • #47
Neutron stars are generally identified by being pulsars, and the whole reason why pulsars pulse is that their magnetic poles are not on the spin axis (and indeed are not even necessarily directly opposite one another).
Material in an accretion disk is in a semi-stable orbit, initially driven by the angular momentum of the accreting material, but effects such as friction, pressure and interactions with magnetic fields eventually cause material to fall into unstable orbits and either fall to the surface or get ejected, especially as jets. Note that material in a lower orbit needs to move more rapidly to stay in orbit, so if there is any interaction with slower material in a higher orbit, that tends to cause the lower material to fall inwards.
I strongly recommend that you study some of the relevant physics, including introductory information on neutron stars, accretion disks and jets. As I said at the start, the jet creation processes are not fully understood, but I think you need to catch up with current understanding before you try to extend it.
  • Astronomy and Astrophysics
