consuli
- 62
- 4
One of the main issues to send orbiters to (light years) faraway locations is the propulsion problem. Conventional chemical fuels cannot provide enough energy by weight to produce that much thrust.
Nuclear fission provides a lot of energy by weight, but usually radiation energy doe not produce any thrust, as the radiotion goes omnidirectional anywhere.
In the case of beta-negative radiators the emitted particle from the isotope is an electron. And for acclerated electrons however, we already know a lot of energy conversions to transform them into light (which easily can be redirected in a certain direction using mirrors).
The following acclerated electron to light transformation are known:
So, if a short- or medium lifed beta-negative radiating isotope would be put in the middle of a miniature rocket, which further space would be filled with such a transformation medium, light would be generated. Ideally all outer walls of such miniature rocket would be coated with sinousid mirrors, that redirect of the generated light, which can only escape at the rocket back. Thus, the light escaping at the back of the rocket will cause forward thrust.
My questions:
- Cherenkov radiation in transparent mediums like water
- Neon and other nobel gases in flourescent tubes
- Phosphor (e.g. in a CRT screen of an old school TV)
- Certain crystals that are used in beta-radiation-scintillators
My questions:
- Has anyone propsed such nuclear fueled light-space-drive already? (If so, where can I find it?)
- How much thrust would be generated from e.g. one kilogram 137-cesium, if the energy efficiency would be 50%?
