Could fluorescence quenching be used for making 3D images?
In summary: This does not seem reasonable.Are you responding to the post as a whole, or to only the idea of "presenting dynamic 3D forms in high resolution"?
miraiw
Looking at the image from this wikipedia article, it looks like there's a selective fluorescing of the quinine dependent on the presence of chrolide ions in the solution.
If the concentration of chloride ions in a solution could be controlled into a particular shape, shining a violet laser on the solution would show the shape, yes? How possible is it to control precisely concentrations of particular in a solution? I've not read anything about it, but I can't tell if it's not possible or just isn't done.
It's not clear what you are really asking- do you have a particular experiment/measurement in mind?
What I have in mind is a programmable medium for presenting dynamic 3D forms in high resolution. I don't think I know enough to measure or expirement with this, but the image in the article seemed suggestive of a system where an array of lasers would be directed towards a volume of quinine, the fluorescence appearing only in regions of high-concentrations of chloride ions. My difficulty here is that I've never heard of controlling concentration gradients in a solution in the ways that would be necessary to generate recognizable images. I could do research into this, but if someone with greater knowledge of fluids suggested that the task would be too difficult, that would save me some time.
Does this seem reasonable?
miraiw said:
What I have in mind is a programmable medium for presenting dynamic 3D forms in high resolution. <snip>
Not to me.
I think I could have made my question clearer. Please look at this video here:
The demonstration in the video is exactly the kind of thing I'm interested in. Probably you would not call this 'high resolution', but I was comparing it to smaller cubes in a sparser grid. However, I don't want to use LEDs because I'm curious about other ways to replicate the visual quality of this voxel-based display. I hit on the fluorescence quenching, and as I mentioned, it looked like something that could be used for this thing. Why wouldn't you use this phenomenon for making a display like in the video besides there being other ways of doing it?
<snip>
Time-lapse 3D images of subcellular dynamics is extremely interesting, the method you mention is highly indirect and overly complicated.
An example of alternatives that directly image items of interest: fluorescent fusion proteins, intracellular Ca++ or NO with fluorescent indicator dyes, etc. etc.
One basic problem about what you have is that, to show a proper three dimensional image, you have to be able to produce an opaque dark surface as well as the bright parts of your image. If you cannot do this, the dark parts of the image will be transparent and you will see the stuff behind that you shouldn't be able to. So what you need is to be able to produce light absorbing regions as well as light emitting regions. That YouTube video consists of 'seller's images' but even they have transparent bits in them. Pretty but no fidelity.
Back to the drawing board, I think - if you want good 3D telly. A possible application for some things though.
Related to Could fluorescence quenching be used for making 3D images?
1. What is fluorescence quenching?
Fluorescence quenching is the process of reducing or eliminating the fluorescent emission of a substance. This can occur through various mechanisms, such as collisional quenching or energy transfer between molecules.
2. How is fluorescence quenching used in 3D imaging?
In 3D imaging, fluorescence quenching is used to map the 3D distribution of molecules in a sample. By selectively quenching certain fluorophores at different depths, a 3D image can be reconstructed.
3. Can any type of molecule be used for fluorescence quenching in 3D imaging?
No, not all molecules are suitable for fluorescence quenching in 3D imaging. The molecules must have a specific structure and properties that allow for efficient quenching, and they must also be compatible with the imaging technique being used.
4. What are the advantages of using fluorescence quenching for 3D imaging?
One of the main advantages of using fluorescence quenching for 3D imaging is its ability to provide high spatial resolution, allowing for detailed mapping of molecular distributions in a sample. It is also a non-invasive technique, meaning that the sample is not destroyed or altered during imaging.
5. Are there any limitations to using fluorescence quenching for 3D imaging?
Yes, there are some limitations to using fluorescence quenching for 3D imaging. For example, it may not be suitable for imaging certain types of samples, such as thick or opaque samples. Additionally, the process of quenching can be affected by various factors, such as temperature and pH, which may need to be carefully controlled during imaging.
  • Materials and Chemical Engineering
  • Mechanical Engineering
