Could Interference be used to effect one way radiation?
In summary, blackbody radiation from two sources at the same temperature cannot create a maximin minimum interference pattern.
philrainey
90
If you have radiation from two black body sources at same temperature will they make a maximin minimum Interference pattern that another small black body sphere can be inserted in, in a minimum space. Will they radiate low radiation to the sphere (Due to the radiation energy in that area been low due to Interference) But the radiation to the two sources be a higher energy value?
http://en.wikipedia.org/wiki/Interference_(wave_propagation)
Science news on Phys.org
No, the blackbody radiation from the two sources is not coherent.
Likes 1 person
Just to elaborate somewhat on #2. A black-body emits random phase radiation over a very broad frequency spectrum (Planck spectrum). Interference is entirely absent in any meaningful sense. To quote from the very first part of Wiki article http://en.wikipedia.org/wiki/Black-body_radiation
"Black-body radiation is the type of electromagnetic radiation within or surrounding a body in thermodynamic equilibrium with its environment, or emitted by a black body (an opaque and non-reflective body) held at constant, uniform temperature. The radiation has a specific spectrum and intensity that depends only on the temperature of the body.[1][2][3][4]."
'thermodynamic equilibrium' is the operative expression here. Any inserted third body feels the same random radiation spectrum regardless of location relative to the other two - if in a uniform temperature environment. Which of course would not apply if the first two black bodies are internally heated to temperatures differering from the external environment. And while emissivity of materials varies widely, precisely the same black-body spectrum is emitted by any material if in temperature equilibrium with it's environment. You will doubtless recall from a posting elsewhere that other considerations may also enter, having nothing to do with interference or surface emissivity phenomena.
Thankyou .
I can confirm that interference can indeed be used to affect one-way radiation. This phenomenon occurs when two or more waves of the same frequency and amplitude meet at a certain point in space and either reinforce or cancel each other out. In the case described, if two black body sources are emitting radiation of the same temperature and are positioned in a way that creates an interference pattern, then the radiation energy in that specific area will be affected.
It is possible that the interference pattern created by the two sources could result in a minimum or maximum radiation energy at a certain point in space. This would depend on the specific arrangement and distance between the sources. If a small black body sphere is inserted into this area, it is likely that it would experience lower radiation energy compared to other areas where the interference is not occurring.
However, it is important to note that the overall radiation energy from the two sources would not decrease. In fact, the energy would still be the same, but it would be redistributed due to the interference pattern. This redistribution of energy is a key aspect of interference and can be observed in various wave phenomena.
In conclusion, interference can be used to affect one-way radiation and can result in areas of lower or higher radiation energy. However, the overall energy from the sources remains constant. It is important to carefully consider the positioning and arrangement of sources in order to observe and understand the effects of interference on radiation.
FAQ: Could Interference be used to effect one way radiation?
What is interference?
Interference is a phenomenon that occurs when two or more waves overlap and interact with each other. This interaction can result in constructive or destructive interference, depending on the phase difference between the waves.
How could interference be used to affect one way radiation?
Interference can be used to manipulate the direction and intensity of radiation. By creating specific interference patterns, it is possible to steer radiation in a desired direction or even block it completely in certain areas.
Can interference be used to manipulate all types of radiation?
Yes, interference can be used to manipulate all types of radiation, including electromagnetic radiation (such as light and radio waves) and even particle radiation (such as electrons and protons).
Are there any practical applications of using interference to affect one way radiation?
Yes, there are several practical applications of using interference to affect radiation. One example is in the design of antennas for wireless communication, where interference patterns are used to direct and amplify radio waves in a specific direction. Interference is also used in imaging techniques, such as holography, to create high-resolution images.
Are there any limitations or challenges in using interference to manipulate radiation?
One limitation of using interference to manipulate radiation is that it requires precise control over the phase and amplitude of the waves. This can be challenging to achieve, especially for complex interference patterns. Additionally, interference can also be affected by external factors such as environmental conditions, which can make it difficult to maintain consistent results.
