Could my textbook sample problem be wrong?
  • Thread starter p3t3r1
  • Tags
    Textbook
In summary: I think they were just "proofreading" on the cheap, i.e. just had engineers check the math and not the physics. it caused a lot of confusion but at least we weren't graded on it.In summary, the conversation discusses the concept of thin film interference and how it affects reflection and transmission of light. The book's solution is incorrect, stating that for constructive interference, the path difference must be a half wavelength, while the correct answer is that it must be an integer multiple of a full wavelength. The conversation also touches on the importance of fact checking in textbooks and the potential consequences of errors.
p3t3r1
33
Well, here is the problem..
In summer months, the amount of solar energy entering a house should be minimized. Window glass is made energy efficient by applying a coating to maximize reflected light. Light in the midrange of the visible spectrum (at 568 nm) travels into energy efficient window glass. What thickness of the added coating is needed to maximize reflected light and thus minimize transmitted light?
(air, n = 1.0, coating, n= 1.4 , glass n = 1.5)
Book's solution:
Reflection occurs both at the air-coating interface and at the coating-glass interface. In both cases, the reflected light is 180 deg out of phase with the incident light, since both reflections occur at a fast-to-slow boundary. The two reflected rays would therefore be in phase if there were a zero path difference. To produce constructive intereference the path difference must be wavelength /2. In otherwords, the coating thickness t must be wavelength /4 , where wavelength is the wavelength of the light in the coating.
My solution:
To produce constructive intereference the path difference must be 1 wavelength, not a half wavelength. Therefore, the coating thickness, t, must be wavelength /2. This makes sense since for reflection, we have phase change of ray 1 been reflected and inverted, which is same as change in wavelength /2. We also have ray 2 been reflected and inverted, which is same as change in wavelength /2. Ray 2 also travels more distance, (t x 2, which would be one wavelength if t = wavelength /2) Therefore, ray 2 would differ from ray 1 by a path difference of 1 wavelength and they would interfere constructively for max reflection. And for transmission, we have ray 1 transmitted through without reflection, hence without a phase change caused by the inversion. Then we have ray 2 reflected, undergo a phase change of 180 degrees, or a wavelength/2. It would also travel 1 wave length more since the extra distance is t x 2. Therefore, ray 2 would be half a wavelength from ray 1 and they would interfere destructively to minimize.
The problem is though. if this sample problem is wrong.. so would all the exercises and pratice problem answers.. which would really suck.
how does interference affect reflection? are you saying that if the waves were out of phase then the film wouldn't reflect?
The book's solution is wrong; yours is correct.
p3t3r1 said:
Book's solution:
So far, so good.
Nonsense. For constructive interference--and maximum reflection--the optical path length difference must be an integer multiple of full wavelengths.
That would produce an anti-reflection coating.
Check and see for yourself; maybe it's just a fluke. (Inexcusable in a sample problem.) What book are you using?
For a correct discussion of thin film interference, go here: http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/thinfilm.html"
I am using the standard Ontario Grade 12 Physics textbook. Nelson 12 Physics.
http://www.school.nelson.com/secondary/science/0176259880/default.html
Luckily I have readily access to university textbooks by Sears, Haliday etc.. so It didn't create as a big fuss as it would.
I checked the erreta for the book and there was no mention of this. They could have least check the sample problems. I don't mind having the answers for the pratice answers wrong. At least we could assume their answers are wrong. Having sample problems wrong would misled thousands of students.
Make sure your instructor is aware of the mistake and reports it to the publisher.
Picking up a theme, textbooks published by reputable publishing houses are generally sent out for checking by independent parties (typically a professor who farms out the task to a graduate student or two). This is an invaluable procedure since it can be very difficult for an author to catch mind blips (oddly enough, the problem is often that he knows too much, not too little). Unfortunately, sometimes mistakes slip through the cracks. This is less common, as I hope and believe, at the university level, but by a regrettable tradition, lower level science textbooks are all to often full of misinformation.
Now compare Wikipedia, where fact checking is chaotic and generally not performed by individuals who have mastered the subject at hand.
my intro E&M lab book was rife with mistakes
Related to Could my textbook sample problem be wrong?
1. Could my textbook sample problem be wrong?
It is possible for a textbook sample problem to be wrong, as textbooks are created by authors who are human and may make errors. However, textbooks typically go through multiple rounds of editing and review to minimize mistakes. Additionally, if you are unsure about a particular problem, you can always consult with your teacher or professor for clarification.
2. How do I know if my textbook sample problem is wrong?
If you are unsure about the accuracy of a textbook sample problem, you can check your answer using a trusted outside source, such as a reliable online calculator or asking a fellow student or teacher for their opinion. If your answer differs significantly from the expected answer, it could indicate that there is an error in the textbook problem.
3. What should I do if I think my textbook sample problem is wrong?
If you believe that you have found an error in a textbook sample problem, you can bring it to the attention of your teacher or professor. They may be able to clarify the problem or contact the textbook publisher to address the issue. It is also helpful to provide specific details and examples of the error to aid in the correction process.
4. Can I trust the sample problems in my textbook?
The sample problems in textbooks are typically thoroughly reviewed and edited before being published. However, it is always possible for errors to occur. It is important to use critical thinking skills and check your answers to ensure accuracy. If you are unsure about a particular problem, consult with a trusted source for clarification.
5. Should I be worried if my answer to a textbook sample problem is different from the expected answer?
It is normal for there to be some variation in answers to textbook sample problems, as long as your method and reasoning are correct. However, if you consistently get significantly different answers, it may indicate that there is an error in the problem. In this case, it is best to seek clarification from your teacher or consult with a trusted source to ensure your understanding is correct.
