C5F8576
Would a professor in a linear algebra, another upper-level math course, or an upper-level physics course take off points if I don't show steps when factoring an equation expression?
The answer to this question depends on so many circumstances that it is not easy to answer. It depends on the person, the task, the kind of teaching, sympathy, application, difficulty level, etc.C5F8576 said:Would a professor in a linear algebra, another upper-level math course, or an upper-level physics course take off points if I don't show steps when factoring an equation?
I'm not sure what you mean by "showing steps when factoring an equation." If you have a matrix equation like ##A^2 - 2A = 0##, there aren't any steps between that equation and ##A(A - 2I) = 0##. Are you thinking about a slightly more complicated equation in which you would need to use, say, the quadratic formula?C5F8576 said:Would a professor in a linear algebra, another upper-level math course, or an upper-level physics course take off points if I don't show steps when factoring an equation?
Hi,Mark44 said:I'm not sure what you mean by "showing steps when factoring an equation." If you have a matrix equation like ##A^2 - 2A = 0##, there aren't any steps between that equation and ##A(A - 2I) = 0##. Are you thinking about a slightly more complicated equation in which you would need to use, say, the quadratic formula?
BTW, you don't "factor an equation." You can factor expressions that appear on one or both sides of an equation.
That's exactly the point of my uncertainty. There aren't any steps between ##\frac{x^3-x^2-6x}{x^2+2x}## and ##\frac{(x+2)(x-3)}{(x+2)}##. If you went directly from ##\frac{x^3-x^2-6x}{x^2+2x}## to ##x - 3## without showing the factorization of ##x^3-x^2-6x##, taking points off would probably be reasonable.C5F8576 said:Hi,
I mean factoring an expression, e.g. ##\lim_{x\to-2}\frac{x^3-x^2-6x}{x^2+2x}##
into ##=\lim_{x\to-2}\frac{(x+2)(x-3)}{(x+2)}## and ultimately ##=\lim_{x\to-2}(x-3)##.
That's an interesting contrast. The less advanced the course, the more attention needs to be placed on what the students show for the skills and concepts. For the more advanced courses, maybe professor is less concerned with the less advanced but still extremely important skills, and is less worried about good sequences of solution steps being shown in students' works.C5F8576 said:I am not taking a particular math course this semester so it's difficult to ask a specific professor. I'm just preparing for future math courses so I wanted a general sense of what a professor would do. In the past, my physics professors haven't taken points off for not fleshing out each mathematical step while my CS high school teachers and college professors, and high school math teachers have.
Yes, points can be taken off for not factoring if the problem specifically asks for it or if factoring is a necessary step to simplify the expression or solve the equation correctly.
In many cases, it is necessary to show the factoring step to demonstrate your understanding of the process. Even if the final answer is correct, omitting required steps can result in partial credit.
Factoring is typically required when solving quadratic equations, simplifying expressions, or when the instructions explicitly ask for it. Always read the problem carefully and follow any specific instructions given.
If the problem does not specify that factoring is required, you may not lose points as long as your solution is correct and complete. However, showing your work is generally good practice and can help avoid any confusion.
Yes, partial credit can often be awarded for correctly factoring an expression, even if the final answer is incorrect. Showing your work, including factoring steps, can demonstrate your understanding and earn you partial points.
