RobertGC
- 93
- 2
- TL;DR Summary
- Can pressure washers throw water stream thousands of meters into the air?
The JetLev water pack puts out about 60 psi but can lift a 400 pound weight 30 feet in the air.
A lot of water can be provided by just those water jet pack units, 1,000 gallons per minute, providing 400 pounds of force, all of that powered by a 200 hp pump that trails behind remaining in the water:
According to the formulas, you can get 10 meters height of a water stream for each bar(atm) of additional pressure. There are pressure washers than can put out 4,500 psi, 300 bar. Then theoretically they could send a water stream 3,000 meters in the air, 3 km(!)
Then could we use these with a water source such as rivers, creeks, and lakes to put out fires kilometers away?
Pressure washers for home use only put out a few gallons per minute. But we could combine thousands of them for this purpose.
Has anyone tried simply pointing a pressure washer straight up at its highest pressure setting, that is, not as a spray, to see how high the water stream can go?
