Could someone explain why work is force times distance?
In summary, the conversation discussed the concept of work and how it is derived from other principles, such as force and distance. It was mentioned that work is a useful quantity and is related to the change in kinetic energy. The conversation also touched on the idea of work in relation to simple machines and the conservation of energy. It was concluded that in classical mechanics, it is best to think of matter as made of differential elements rather than atoms. The conversation also briefly mentioned the difficulty of marking a thread as solved on the platform.
Mahkoe
I was wondering if someone could help me out with understanding the intuition behind multiplied units.
For example, with speed, the units are divided (distance/time, m/s, etc.). The unit means how many meters you go in one second, which is the value received after dividing the distance by the time. But with work, it's force times distance (and with force, it's kg times acceleration). I'm trying to figure out what that represents, but I'm stumped. I was wondering if someone might be able to help me with this.
Thank you
Likes Ignorant Engineer
Well, its generally a definition.
We make up some magical quantity we call 'work', and define it (for seemingly no reason) to be force x distance. Then it turns out that this 'magical quantity' is really useful (like being equal to the change in kinetic energy), so we keep using it.
So it's just a derivation of other principles? I thought maybe there was an intuition behind it
I think I remember reading that the concept of "work" as force times distance comes from the physics of simple machines such as levers, where it was observed that the force times distance is the same on the two ends of the lever. You can get a larger force (over a shorter distance) on one end of the lever by exerting a smaller force (over a longer distance) on the other side, but the amount of work is the same on both ends.
Alright then. Anyone know how to mark a thread as solved?
Thanks
When the work consists of moving bags of cement upstairs, it's obvious that you will do twice the work, if you do 2 staircases instead of one staircase, and it's also obvious you do twice the work, if you carry 2 bags instead of 1.
If I just hold the bag of cement in my arms, my arms get tired so presumably they are doing some kind of work? If that is so, then if a place the bag of cement on a table to give my arms a rest, is the table then doing work?
Neither you nor the table are doing work on the bag of cement - which is the relevant Force times Distance involved. However, your muscle fibres are doing work on bits inside your arm as they switch on for a while, move a bit, then relax. There is no corresponding movment inside the table. That's the difference.
Regarding the original question. Perhaps start with..
Power = force * velocity
To me that's intuitive. The faster you want to move a car the more power you need.
power = dE/dt
Velocity = ds/dt
so
dE/dt = force * ds/dt
Integrate to give
dE = force * ds
or
Work = force * distance.
sophiecentaur said:
Neither you nor the table are doing work on the bag of cement - which is the relevant Force times Distance involved. However, your muscle fibres are doing work on bits inside your arm as they switch on for a while, move a bit, then relax. There is no corresponding movement inside the table. That's the difference.
But on the surface of the table, aren't the individual atoms all jiggling around - and now and then push against an atom on the surface of the bag of cement and make that move against the force of gravity? So why aren't those atoms performing work in the same that the atoms in my muscle fibres are performing work against gravity?
It is best not to talk about atoms and such in classical mechanics.
Just think of matter as made of differential elements that still retain macroscopic properties.
Of course, this it not true but it is enough for classical mechanics.
You should look into continuum mechanics for non-particle interactions, (by particle I am not referring to atoms or electrons, simply point masses).In the case of the cement bag being on a table, no work is done since the bag is not displaced.
Work is useful because the work done on an object is equal to the difference between it's final and initial kinetic energies. In a gravitational field, the work done is also equal to the initial gravitational potential energy minus the final gravitational energy (the opposite of the former).
These facts lead us to the conservation of energy.
Back to the bag of cement, since the potential energy of the cement does not change (it is at the same position), the difference is 0 and hence no work is done.
If you are wondering why we shouldn't talk about atoms in classical mechanics, it is because Newtons laws are not valid on that scale.
Thanks
Did you ever see the Sourcerer's Apprentice in Disney's Fantasia? You asked a simple question and got a satisfactory answer but this is PF. The thread just won't stop. AAArrrgh.
Thank you
Force and distance are vectors. There are two mathematical operations we can do multiplying vectors, the dot product and the cross product. The dot product is a scalar, and this is work. The cross product is torque. The answer to your question is that we simply look at the two operations we can do with vectors.
Ten men working for two hours gives you 20 man-hours. That amount of effort can often be re-configurable so that four men could work for five hours and get the same result. That is an example where multiplying units yields a useful quantity - man hours.
Likewise, with levers, you use Moments (a force times a distance) in the calculations. Does that help with "intuition"?
Interesting comment. I like to view it as an example of applying mathematical principles to physics, multiplying vectors.
It's just another 'level' of approach. I could suggest that not everyone would involve vectors in their immediate 'intuitive' approach to a topic. They'd already be half way there if vectors were not a problem.
We must teach the math behind the physics. Such as vectors.
Eventually.
Why eventually? Math is a collection of arbitrary consistent statements. Physics takes the logic of math and compares it with observation and experiment. This is a physical theory.
That really helped. Thanks!
Do these forums have reputation system (such as the kudos in dream.in.code)?
Isn't there a hierarchy involved here? You can't run before you can walk, surely. Give someone vectors when they are ready for man-hours may not be optimal.
FAQ: Could someone explain why work is force times distance?
What is the equation for work?
The equation for work is work = force x distance.
How is work related to force and distance?
Work is directly proportional to both force and distance. This means that as either force or distance increases, work also increases.
What does the equation for work represent?
The equation for work represents the amount of energy transferred when a force is applied over a certain distance.
Why is work measured in joules?
Work is measured in joules because it is a unit of energy. One joule is equal to the amount of work done when a force of one newton is applied over a distance of one meter.
How is the direction of force related to the direction of work?
The direction of force and the direction of work are directly related. If the force and displacement are in the same direction, then work is considered positive. If they are in opposite directions, then work is considered negative.
