Could someone please explain this? (HW-related)
  • Thread starter Jamin2112
  • Tags
    Explain
In summary, the conversation discusses the process of converting a set of equations, such as dx/dt = F(x,y) and dy/dt = G(x,y), into a system of equations in the form of (x' y')T = J * (x y)T, where J is the Jacobian Matrix. This conversion is a local approximation of the F and G functions to a linear or affine function, using the concept of a tangent plane approximation. The resulting equations can be written as a matrix equation, which helps to understand the process.
Jamin2112
986
So the last thing we got to learn before studying for finals ...
... was converting something like
dx/dt = F(x,y)
dy/dt = G(x,y)
into a ...
... system of equations like (x' y')T = J * (x y)T,
where J is the Jacobian Matrix [ (∂F/∂x ∂G/∂x)T , (∂D/∂y ∂G/∂y)T ].
I'm just wondering why exactly that works. Could someone show me a proof or something? Being the weird dude I am, I need to know these things. :wink:
hm, perhaps you're approximating a nonlinear system by a linear. I'm thinking 'taylor expansion', but then this may be my response to everything. do you happen to know if the initial point is [F(x_o,y_o),G(x_o,y_o)]=[0,0]? that might help clarify things a bit...
xaos is right, this "conversion" of the problem is a local approximation of your F,G functions to an linear (or affine) function. In general the set of equations you give is not linear, the only way to "linearize" it is to do this Taylor expansion (assuming the F and G were not already linear).
Alright. I'll just roll with it.
In other words, at some point [itex](x_0,y_0)[/itex], F(x,y) is replaced by its "tangent plane approximation",
[tex]\frac{\partial F}{\partial x}(x_0,y_0)(x- x_0)+ \frac{\partial F(x_0, y_0)}{\partial y}(y- y_0)+ F(x_0, y_0)[/tex]
and G(x, y) is replaced by its "tangent plane approximation",
[tex]\frac{\partial G}{\partial x}(x_0,y_0)(x- x_0)+ \frac{\partial G}{\partial y}(x_0, y_0)(y- y_0)+ G(x_0, y_0)[/tex]
Now, you have the two equations
[tex]\frac{dx}{dt}= \frac{\partial F}{\partial x}(x_0,y_0)(x- x_0)+ \frac{\partial F(x_0, y_0)}{\partial y}(y- y_0)+ F(x_0, y_0)[/tex]
[tex]\frac{dy}{dt}= \frac{\partial G}{\partial x}(x_0,y_0)(x- x_0)+ \frac{\partial G}{\partial y}(x_0, y_0)(y- y_0)+ G(x_0, y_0)[/tex]
which we can write as the matrix equation
[tex]\frac{d}{dt}\begin{pmatrix}x \\ y\end{pmatrix}= \begin{pmatrix}\frac{\partial F}{\partial x}(x_0, y_0) & \frac{\partial F}{\partial y}(x_0, y_0) \\ \frac{\partial G}{\partial x}(x_0, y_0) & \frac{\partial G}{\partial y}(x_0, y_0)\end{pmatrix}\begin{pmatrix}x- x_0 \\ y- y_0\end{pmatrix}+ \begin{pmatrix}F(x_0, y_0) \\ G(x_0, y_0)\end{pmatrix}[/tex]
FAQ: Could someone please explain this? (HW-related)
What does the assignment prompt mean?
The assignment prompt is a set of instructions or guidelines given to you by your instructor. It outlines the topic or concept you need to understand and the task you need to complete. Make sure to carefully read and understand the prompt before beginning your assignment.
How do I start my homework?
Before starting your homework, make sure to review your class notes and any relevant readings. This will help you understand the concepts and material you will need to complete the assignment. You can also break down the assignment into smaller tasks to make it more manageable and set a timeline for completion.
Can I use outside sources for my homework?
It depends on your instructor's guidelines for the assignment. Some assignments may require you to use only class materials, while others may allow you to use outside sources such as textbooks or online articles. Make sure to follow any guidelines provided by your instructor.
How do I know if my answer is correct?
Always double-check your work and make sure you have followed the instructions and guidelines given in the assignment prompt. If you are still unsure, you can ask your instructor or a classmate for feedback. It is also a good idea to do practice problems or review quizzes to test your understanding of the material.
What should I do if I don't understand the material?
If you are struggling to understand the material, don't panic. Start by reviewing your class notes and any relevant readings. You can also reach out to your instructor for clarification or attend any office hours or study sessions they may offer. Additionally, working with classmates or seeking help from a tutor can also be beneficial.
