Could the 3D percolation model explain Regge-Trajectories?
In summary, the latest LHC elastic scattering experimental results and total cross-sections can be explained by three Regge-trajectories: a Reggeon, a (soft) Pomeron, and an Odderon. The Pomeron carries the same quantum numbers as the vacuum and the Odderon has odd symmetry under crossing. This "particle" or trajectory explains why ##pp## and ##p\bar p## total cross-sections are different even at high energies (Pomeranchuck's theorem states that they should be equal). An additional "hard" Pomeron might be needed to explain ##ep## deep inelastic scattering results. Regge-theory allows the construction of different e
Anashim
40
Regge-theory succesfully explains the latest LHC ##pp## elastic scattering experimental results and total cross-sections:
https://arxiv.org/pdf/1711.03288
https://arxiv.org/abs/1808.08580
Three different Regge-trajectories are needed: one Reggeon, one (soft) Pomeron and one Odderon. The Pomeron carries the same quantum numbers as the vacuum and the Odderon has odd symmetry under crossing. This "particle" or trajectory explains why ##pp## and ##p\bar p## total cross-sections are different even at high energies (Pomeranchuck's theorem states that they should be equal and experiments prove otherwise). An additional "hard" Pomeron might be needed to explain ##ep## deep inelastic scattering results.
Regge-theory allows the construction of different efective field theories that are used in QCD in different asymptotic cases (BFKL field equation, for example).
These three trajectories are taken from experiments. Intensive research efforts are being made to explain these three "particles" from first principles (QCD) and the consensus is that they are some sort of collective gluonic behavior involving ladder gluons or "reggeized-gluons", although the problem is far from being solved.
The physical bases of the multiperipheral model are explained in (paywalled):
https://link.springer.com/content/pdf/10.1007/BF02781901.pdf
and in:
"High-Energy Particle Diffraction" 2002, by V. Barone and E. Pedrazzi. Section 5.9.
The emerging picture is that Regge-trajectories are essentially non local objects, involving the addition of multiple gluon ladders, as described in the multiperipheral model:
See, for example, "High-Energy Particle Diffraction" 2002, Chapter 8.
I thought that, perhaps, this collective gluon behavior could be related to some (unknown) critical dynamic phenomenon belonging to one of the known Universality Classes. If you look at the experimental results of total cross-sections of different hadrons and their best fit curves, you cannot help wondering if there is some kind of universal behavior. See for example slides (35) and (36) in:
https://indico2.riken.jp/event/2729/attachments/7480/8729/PomeronRIKEN.pdfSo, the question was if the three trajectories, defined by:
$$\alpha_{\mathbb R}(t)=\alpha_{\mathbb R}(0)+\alpha_{\mathbb R}^{'}(0)t$$
$$\alpha_{\mathbb P}(t)=\alpha_{\mathbb P}(0)+\alpha_{\mathbb P}^{'}(0)t$$
$$\alpha_{\mathbb O}(t)=\alpha_{\mathbb O}(0)+\alpha_{\mathbb O}^{'}(0)t$$
where:
  • ##\alpha_{\mathbb R}(0)\simeq 0.55##
  • ##\alpha_{\mathbb P}(0)\simeq 1.1##
  • ##\alpha_{\mathbb O}(0)\simeq 1##
  • ##\alpha_{\mathbb R}^{'}(0)\simeq 0.86 GeV^{-2}##
  • ##\alpha_{\mathbb P}^{'}(0)\simeq 0.25 GeV^{-2}##
  • ##\alpha_{\mathbb O}^{'}(0)\sim 0.2 GeV^{-2}##
could belong to some Universality Class.
I had a quick look and realized that the three first non-dimesional numbers are close to some of the critical exponents belonging to the 3D-directed percolation universality class.
Someone attracted my attention to the fact that the directed percolation universality classes had been originaly claculated in:
https://sunclipse.org/wp-content/downloads/2013/04/cardy-etal1980.pdf
using a "Reggeon-Field Theory". That could mean that the Regge-trajectories had been inserted by hand in the theory from the very beginning.
This kept me thinking for a long while. However I do not think that it is an issue, because you cannot introduce anything by hand because of renormalization. If this F.T. represents a critical phenomenon, it MUST have a fixed point (possibly in the IR) whose running coupling constants stop changing (possibly below a momentum scale). This FP defines the critical exponents of the theory.
Another important concern is that critical exponents must be non-dimensional. Can the non-dimensional ##\alpha_{\mathbb R}^{'}(0)##, ##\alpha_{\mathbb P}^{'}(0)## and ##\alpha_{\mathbb O}^{'}(0)## be obtained? I think that the answer might be yes (using the impact parameter representation), which is briefly explained in:
http://school-diff2013.physi.uni-heidelberg.de/Talks/Poghosyan.pdf
In slide (22) it can seen that the diffraction peak shrinks with the C.O.M. energy ##s## and, therefore, so does the diffraction dip energy ##t_{min}##.
In:
https://arxiv.org/pdf/1609.08847.pdf
expression (11) gives the diffraction dip energy, ##t_{min}##, and, if I am not wrong, the Pomeron non-dimensional slope is denoted by ##a_2\sim 0.01##.
Could any of the DP critical models be consistent with these results? IMO yes, the 3-DP model could be consistent with them (although I am well aware that it is a bit of a leap to consider that the 3DP model could be the critical dynamic phenomenon explaining Regge-trajectories). Its critical exponents are shown in page 56 of this reference:
https://lanl.arxiv.org/pdf/cond-mat/0001070v2
Moreover, I realized a few weeks ago, that the scattering amplitude ##A_{pp}(s,t)## depends only on two squared momenta and the model expected to be consistent with the data was the 2-DP model which, definitely is not. However, now I think that since the collective phenomenon involves gluons, which are not the relevant interacting "particles" in Regge Theory, this is no longer a problem. They just "live" in different configuration spaces.
Well, I guess I am going to be laughed at for suggesting this idea. However, I have tried to explain and document every single step that I have followed before making this question. If I am totally wrong it will not be difficult to find out where it is that I am wrong.
There is something relevant that I did not mention.
In (paywalled, the last two papers):
https://www.nature.com/collections/rxsztdqblr/
it is experimentally checked that the directed percolation models describe well the critical transition from laminar to turbulent flow. However, the model only works in a narrow neighbourhood of the critical condition.
The problem is that the incompressible Navier Stokes equations are Galileo-invariant, not Lorentz-invariant. This disease may be somewhat "cured" doing a "pseudo-relativistic" correction. Please, bear in mind that the incompressible Navier-Stokes equations approximation breaks down as Mach's number approaches 1 from (well) below.
Instead of considering the critical opertator:
$$p_c:=\frac{|\mathbb{Re}-\mathbb{Re}_c|}{\mathbb{Re}_c}\propto \frac{|U-U_c|}{U_c}$$
where ##Re## denotes Reynold's number, ##c## critical condition and ##U## the reference velocity, you can use, instead:
$$p_c:=\frac{|\mathbb{Re}-\mathbb{Re}_c|}{\mathbb{Re}_c\Big [1+\frac{\mathbb{Re}\mathbb{Re}_c}{\mathbb{Re}_m^2}\Big ]}\propto
\frac{|U-U_c|}{U_c\Big [1+\frac{UU_c}{U_m^2}\Big ]}$$
where ##m## denotes the speed of sound condition (Mach's number=1). In this way, the validity of the percolation model may be extended deep into the turbulence region. The speed of sound may play here a similar roled to the speed of light in relativity.
Poincare's invariance must be somehow restored if incompressible Navier-Stokes equations and hadron interactions are to be mutually related by the same Universality Class model.
Now, I'm finally done with this issue.
If everything I said in the previous posts turns out to be true (I am going to the the calculations to see if the hypotheses hold true), a trivial consequence would be that:
$$p_c:=\frac{U_c}{U_m}$$
is a universal number. It would only depend on the spatial dimension ##d## number of the laminar to turbulent critical transition. ##U_c## is the critical velocity and ##U_m## the speed of sound in the incompressible fluid. These numbers should match those of the different ##p_c## of the Directed Percolation Models. If this is not true then some of my hypotheses do not hold true (I would be wrong).
Could anyone with access to the data, please, do the calculations? I'm going to try to collect the data with a colleague who is specialized in fluid dynamics, but I'm not sure if we'll be able to get them.
Typical critical Reynolds ##\mathbb{Re}_c## are so low compared to sound Reynolds ##\mathbb{ Re}_m## in usual incompressible fluids that it is pretty sure that the "pseudo-relativistic" corrections do not play any role in the deviations from critical behaviour deep inside the turbulent phase (which are, of course, expected to happen).
I was totally wrong.
Even though the critical condition can be established for Non-Directed Percolation Models, I have not been able to find any sotochastic model that clearly established a threshold probability (or critical probability) for continuous d-Dimensional Directed Percolation Model.
The hypothesis if the universality nature of ##\frac{U_c}{U_m}## is probably wrong too.
For reference:Nature's monograph on transition to turbulence and Directed Percolation models (paywalled):
https://www.nature.com/collections/rxsztdqblr/I am very confused. Letter number (5) of Nature's monograph on turbulence shows NO sign of turbulence density saturation and the agreement between experimental resuts, simulations and the 1+1 Directed Percolation Model is impressive even in the fully developed turbulent phase, where the agreement is unexpected.
However, Letter number (4) shows a good degree of agreement between experiments and the 2+1 Directed Percolation Model only in a narrow interval of Re numbers. I find two issues of this paper a bit strange:
  1. Turbulent conditions are enforced at the inlet (so that transients are quicker, so I unerstand why they've done it but I'm not sure what its implications are).
  2. Figure (2.c) shows that the non-turbulent regions seem to be correlated with the edges of the channel. Could this at the origin of the turbulent-phase saturation reported in this letter?
I will try to talk again to a colleague who is specialyzed in Fluid Dynamics and ask him what he thinks about this issue, because the authors of Letter number (5) are very assertive about their results (saturation of the turbulent phase density).
What I wrote about critical velocity being much smaller than the speed of sound is, of course, true. I was completely wrong about pseudo-relativistic corrections being able to explain the above mentioned saturation effect.
Related to Could the 3D percolation model explain Regge-Trajectories?
1. How does the 3D percolation model relate to Regge trajectories?
The 3D percolation model is a statistical model used to study the behavior of networks or clusters. It is based on the concept of percolation, where a system transitions from being mostly isolated to being mostly connected. This model has been used in physics to study the formation and properties of hadrons, which are particles that make up the building blocks of matter. Regge trajectories, on the other hand, are a theoretical framework used to explain the behavior of hadrons. They describe the relation between the spin and mass of these particles. Therefore, the 3D percolation model can be used to understand the underlying mechanisms behind Regge trajectories.
2. What evidence supports the use of the 3D percolation model in explaining Regge trajectories?
Several studies have shown a strong correlation between the predictions of the 3D percolation model and experimental data on the properties of hadrons. For example, the model accurately predicts the energy of the first excited state of hadrons, which is a key component of Regge trajectories. Additionally, the model can also explain the observed linear relationship between the spin and mass of hadrons, known as the Chew-Frautschi plot.
3. Are there any limitations to using the 3D percolation model to explain Regge trajectories?
While the 3D percolation model has been successful in explaining many aspects of Regge trajectories, it is not a complete theory. It does not take into account the strong force, which is responsible for binding quarks together to form hadrons. This force is crucial in understanding the behavior of hadrons and cannot be fully described by the 3D percolation model alone.
4. How does the 3D percolation model differ from other models used to explain Regge trajectories?
The 3D percolation model differs from other models, such as the string model or the quark model, in that it does not rely on specific assumptions about the internal structure of hadrons. Instead, it focuses on the overall behavior of hadronic systems as a whole. This allows for a more universal approach to understanding the properties of hadrons.
5. Can the 3D percolation model be applied to other areas of physics?
Yes, the 3D percolation model has been used to study a variety of systems in addition to hadrons. It has been applied to understand the behavior of polymers, magnetic materials, and even social networks. Its versatility and ability to capture the emergence of critical phenomena make it a valuable tool in many fields of physics.
  • Beyond the Standard Models
