Could there have been another value for Pi?
  • Thread starter musicgold
  • Tags
    Pi Value
In summary: See post #3. We define ##\pi_0## in terms of a Euclidean circle. And we define ##\pi_1## in terms of a great circle on a sphere. Then ##\pi_1 = 2##. That doesn't change ##\pi_0##. And, it doesn't mean that ##\pi_1## replaces ##\pi_0## in mathematical formulas such as:$$e^{i\pi} + 1 = 0$$
musicgold
304
Not a homework problem; just wondering why the relation between the circumference and diameter of circle is so set in stone?
Does it have anything to with the properties of the fundamental particles? Given the shape of circle so abundent in this universe, could a universe have been created where the value of Pi was different? Why don't we see such fixed relationship with any other shape but the circle?
Thanks
Likes Delta2
musicgold said:
Homework Statement:: Not a homework problem; just wondering why the relation between the circumference and diameter of circle is so set in stone?
Yes.
musicgold said:
Relevant Equations:: Does it have anything to with the properties of the fundamental particles?
No.
No. It is defined per the construction of a (flat) circle.
We do. The relation between the circumference and the diagonal of a square is ##2\sqrt{2}.##
musicgold said:
Thanks
Likes Delta2
The ratio between the diameter and circumference of a circle is determined by the geometry of the space it is in. A circle drawn on a curved surface like a globe or a saddle would have a different ratio. A lot of geometric constants would be different. For instance, the sum of the angles of a triangle would not be 180.
Likes Delta2
So if we had a universe with a different geometry of its space, then that universe would have different value for ##\pi## right?
To put a slight objection with what @fresh_42 said, some of the properties of the fundamental particles depend on the pi, for example the hypothetical classical radius of the electron is $$r_e=\frac{1}{4\pi\epsilon_0}\frac{e^2}{m_ec^2}$$
https://en.wikipedia.org/wiki/Classical_electron_radius
If the universe had a wildly different geometry, I.e. not locally approximately Euclidean, then intelligent life may not have invented Euclidean geometry. But, if they did, then ##\pi## would still be ##\pi##
The equation assumes spatially Euclidean geometry. In the hypothetical universe above, then these sort of formulas could be very different. In any case, if ##\pi## appeared in these formulas it would be the same mathematical constant. That's not to say a different mathematical constant would appear instead.
PeroK said:
If the universe had a wildly different geometry, I.e. not locally approximately Euclidean, then intelligent life may not have invented Euclidean geometry. But, if they did, then π would still be
Er, sorry if the universe was not Euclidean, the ratio of the circumference of a circle (I am not sure how we would define a circle in that universe) to the diameter of a circle would still be 3.14159...?
The universe is not Euclidean. That doesn't mean there isn't (still) Euclidean geometry.
  • Skeptical
Likes Delta2
Yes it's not Euclidean (though locally it is approximately euclidean, at least here in planet earth).
##\pi## is fundamentally defined as the ratio of the circumference to the diameter of a circle in a Euclidean plane. It's not the ratio of the circumference to the diameter of a circle in any geometry.
Now you talking... It depends how we would define a circle in a different geometry .
And how we would define pi...
Then it's not ##\pi## any more.
Yes ok, but in the spirit of the OP he defines ##\pi## as the ratio of a circle in a hypothetical universe with a hypothetical other than euclidean geometry.
$$e^{i\pi} + 1 = 0$$And, it doesn't make ##2## a fundamental constant with the numerous properties that ##\pi_0##, the real ##\pi##, has!
Yes ok i get your points, euler's identity and other properties hold for the pi of the euclidean geometry and not for the pi of the hypothetical universe.
FAQ: Could there have been another value for Pi?
What is the value of Pi?
The value of Pi is approximately 3.14159, but it is an irrational number with infinite decimal places.
How was the value of Pi discovered?
The value of Pi has been studied for thousands of years by mathematicians and scientists. The ancient Greeks were the first to approximate Pi as 3.14, and it has been refined and calculated more accurately over time.
No, Pi is a mathematical constant that represents the ratio of a circle's circumference to its diameter. It is a fundamental property of circles and cannot have another value.
Are there any alternative values for Pi?
There are alternative methods for calculating Pi, such as using infinite series or continued fractions, but they all converge to the same value of approximately 3.14159.
Is it possible to find the exact value of Pi?
No, as an irrational number, Pi cannot be expressed as a finite decimal or fraction. It is an infinite and non-repeating decimal, so it can only be approximated to a certain number of decimal places.
