Could we stop a tornado this way?
  • Thread starter Fearguy1234
  • Tags
    tornado
In summary: However, the effect would still be small - it is by no means guaranteed that a rocket engine is sufficient to stop it.
Fearguy1234
I've always had an idea as to how to stop tornado's, and this is my idea. The idea is that we use Jet engines mounted onto the back of trucks, or vehicles, that are capable of handling them, with them also able to handle large amounts of fuel. Jet engines are extremely powerful. The SR-71 Blackbird uses a Pratt & Whitney J58 Jet engine, that is capable of reaching Mach 3.35. Mach 3.35, is equal to 2570.352 Miles per hour. The fastest winds ever recorded in a tornado, were 318 Miles per hour, recorded in the Oklahoma City tornado, occurring on May 3, 1999. The J58 Jet engine's force completely OVER KILLS the fastest winds ever recorded in a tornado, and the J58 is just a prime example, of the many commercial grade engines available to use aswell, that could create nearly the same force. Also, it's known that just a simple commercial jet engine, has the thrust capability of ripping pavement off of a Runway, which is why aircraft seldom use maximum power taking off. What I am asking is this: If jet engines could logically become deployed in front of a tornado, and used, could it stop the tornado? Their are three main ways I would do it. The first way, is to blow the jet engine at the tornado, possibly moving the tornado away from it's destination (a populated area), and severely disrupting it's force. Another way to fight a tornado, is to point the Jet engine away from it, creating a vacuum like affect, severely disrupting the tornado aswell. The last way to fight it is to disrupt the fast moving winds that blow across the plains of tornado ally (or areas like it), to severely disrupt a tornado's formation, or existence. It's also known that a tornado needs a cold, rainy downdraft along with a warm updraft. Some suggest that heating this cold, rainy downdraft will prevent a tornado's existence. A jet engine, could also provide this heating capacity, in order to disrupt a tornado, and it's structure. I'd like this question to be answered, as the logical questions (such as how costly or how would it work), would work themselves out. These trucks would be very large trucks, possibly having an off road capability. To test the hypothesis of if this would work, small commercial grade Jet engines or Aircraft engines, could be deployed against smaller tornado's, to see if the idea would work. Then, communities facing dangers of large or super tornado's, could upgrade these Jet engines. Please give feedback, would this work? Also, if you have a logical question as to how this operation would work, please ask as well, as I will answer. Thanks!
Take an F2 tornado, at 50m/s, with a typical size of 100m and maybe 1 km high. Its air has a kinetic energy of the order of 100 GJ. The J58 engine can deliver ~150 kN, at 50 m/s this is a power of 7.5 MW. It needs 4 hours of running before its overall energy output matches the energy in a single F2 tornado, and if we consider momentum instead of energy the comparison gets even worse. In addition, the tornado won't sit around and wait. Increasing the number of engines doesn't help much - the jet engines will have a negligible impact on a tornado, no matter what you do.
Trying to prevent a tornado makes the numbers worse by orders of magnitude because you have to cover a huge area.
Likes Evo
Thank you. A four hour running time could be handled, as these engines could sit at idle, whenever a tornado watch is issued (or whenever conditions are favorable.) These engines, if not able to be used to destroy a tornado, could at least manoeuvre a tornado's path out of the way of a town.
You cannot deploy a turbine on every square kilometer of land. And you cannot predict tornados precisely hours in advance, so you do not have 4 hours.
Would still need much more power than available.
Likes Evo
You would not need to deploy an Engine on every square kilometer. Also, you are able to predict tornado's well enough to be able to tell if a major storm front will form later in the day. Also, I have a question. Would a Rocket Engine or Rocket booster produce enough power?
They would come closer, but there is no way to have such a rocket mobile and ready to fire. Also, the effect would still be small - it is by no means guaranteed that a rocket engine is sufficient to stop it.
Also, rocket engines cost much more than rebuilding a few houses.
Likes Evo
If there is no way to have a rocket mobile and ready to fire, then how are Rockets able to launch on the T - Minus count and launch at the push of a button? Now yes, If I did receive money, I would test this on a much smaller scale, But this is still practical. This program would not protect a few houses. This program would protect entire cities and neighborhoods where infamous tornado's, have already hit. The ten costliest tornado's in United States History, added together, equals $16,825,720,100 dollars. That is 16 billion dollars. It takes 150 Million dollars, to launch the average space craft, INCLUDING all of the parts and mechanics that wouldn't be used in the Tornado protection program, so the costs make since. Who knows how much damage all of the tornado's that have ever existed have produced. This program is meant to protect neighborhoods and entire cities from the violent super tornado's that are well known of. A tornado, can hit anywhere in the united states, regardless of it's physical stature such as mountains etc. Now, some of the area's will produce more violent tornado's than others, and that's true. But many majors cities, such as Washington D.C, Oklahoma City, Minneapolis, Minnesota, Green Bay, Wisconsin, Chicago Illinois, Omaha Nebraska, and many more, lie in the wake of tornado alley. This program would receive funding from the major cities I've listed. Why? Because if this program is proven to work, it would be a major insurance write off for the cities. Insurance companies would no longer have to pay out so much money to storm damaged cities, saving the cities, and individual civilians, Millions of billions of dollars in damage, saving more money than is spent.
You are overlooking all the planning and work which must be done to get the rocket ready to fire at the push of a button. It's not something done on a whim or at a moment's notice.
Tornadoes are extremely short-lived storms. The longest distance a tornado touched down in the US was 219 miles, and was estimated to move at more than 70 mph while on the ground. This storm probably had a whole series of funnel clouds touching down in succession as the storm front moved.
The average distance a tornado touches down is about 5 miles, and the width of the path is about 500 feet. The shortest path of destruction was seven feet long.
https://en.wikipedia.org/wiki/Tornado
You'd probably have much better luck convincing cities to build walls 1000 meters high to keep tornadoes out. :wink:
Likes Evo
I do not know. Building walls 1000 meters high up would be an eye sore for people, also being extremely costly to construct, engineer, and build. Yes, it would take a long time to prepare a jet engine, but the main question I am asking, is: Would it work? Thank you for replying.
I'm going through this exercise because you put effort into your question. I do not believe you understand enough to get a real understanding of all of what might be involved.
So, by just using one parameter, Horsepower, here is what I see.
The answer is no. Aside from the logistics of moving and stabilizing the the engines when in position, which is monumental [see last paragraph], let's look at your basic premise - jet engine thrust has enough "oomph" to have a major effect.
Let's see: per this page http://www.dartmouth.edu/~ears5/handouts/TornadoEnergy.html, an F3 tornado 1km wide and 1km high has output of
300000000000 Joules per sec, converting to HP we get 402,144,772 HP. That is 400 million horsepower.
This page from Hill AFB,
http://www.hill.af.mil/library/factsheets/factsheet.asp?id=5786
lists the axial output of the shaft of the engine J58 at 160000HP. So to 'negate(if that were even possible)' for an F3 tornado we need a decent fraction of 400 million HP. At this point we leave Science entirely. So let's pretend we need 100 million HP or about 625 jet engines. Or 625 trucks as you proposed. And the engines have be mounted vertically on really tall racks, that will resist both tornadic winds and the jet thrust, all the while the entire ensemble has to be able to move at decent ground speeds over all kinds of terrain just to confront the tornado... I'm not going to do any more. But I do know if you persist in claiming your idea will work, the mentors here will probably lock the thread.
PS: did you see the number of tornadoes that were created in the Midwest just this last week? It would cost about 10% of the $US GDP to field enough trucks to handle them. And feasibility counts for everything you do in Engineering. Everything.
Likes Evo and billy_joule
It's time to close this down. Fearguy, I suggest that you study tornadoes. I live in tornado country, many times the tv meteorologists are watching tornado activity in one area, when suddenly a tornado comes out of the blue 75 miles away and actually touches down. Sometimes there are multiple tornadoes miles apart. Which will hit open pasture and which will hit a crowded subdivision, no one knows until it happens.
Even when a tornado has been spotted and the sirens go off, you don't know if it's coming at you, or even if a tornado will go all the way to the ground. Last time there where 3 tornadoes at once, I had dropped my daughter off at a friend's just when the sirens went off, it wasn't raining, and the sky just had a few light clouds. I had a 30 minute drive home, with sirens blasting, luckily all three tornadoes were to the west of me where I could see them and they kept to a northerly course while I was heading south. You just do not know with tornadoes. They could have changed course at any time.
Likes davenn
Related to Could we stop a tornado this way?
1. Can we use explosives to stop a tornado?
No, using explosives to stop a tornado is not a feasible solution. Tornadoes are extremely powerful and can reach wind speeds of over 300 miles per hour. Explosives do not have enough force to stop or change the direction of a tornado.
2. Is it possible to use lasers to disrupt a tornado?
No, using lasers to disrupt a tornado is also not a viable solution. Tornadoes are made up of air and water vapor, so they are not susceptible to being disrupted by lasers. Even if it were possible, the amount of energy and precision needed to target and disrupt a tornado with a laser would be too difficult.
3. Can we use a giant fan to blow a tornado away?
Unfortunately, using a giant fan to blow a tornado away is not a practical solution either. Tornadoes are massive and can span over a mile in width, so it would take an incredibly powerful fan to have any effect on it. Additionally, the unpredictable and chaotic nature of tornadoes would make it difficult to target and blow them away.
4. Is it possible to seed a tornado with dry ice or silver iodide to stop it?
No, seeding a tornado with dry ice or silver iodide is not a proven method for stopping a tornado. This technique, also known as cloud seeding, has been used in the past to try and prevent hail formation, but there is no evidence to suggest that it can stop or alter the course of a tornado.
5. Can we build a wall to prevent a tornado from forming?
Building a wall to prevent a tornado from forming is not a practical solution. Tornadoes can form quickly and without warning, so it would be nearly impossible to construct a wall in time to stop one. Additionally, tornadoes can easily travel over or through obstacles, so a wall would not be an effective barrier.
15K
  • Mechanics
  • Mechanical Engineering
  • General Engineering
15K
