Could you find good numerical approximations to math. problem with a PC?
In summary, you should research professional programming to do amateur research in numerical analysis.
Arian.D
101
I've recently taken a basic numerical analysis course in university and the subject intrigues me so much. I know Pascal and C++ fairly well, not very good like a professional programmer, but just to tell you how good I am, I've coded several programs for numerical integration using trapezoidal method, Simpson's rule, midpoint rule and Gaussian quadrature rule.
So my main question is, how far I could go forward doing amateur research in numerical analysis? I've seen that when I try to do arithmetic on large numbers things go wrong and with my limited knowledge of CS I guess a buffer overflow happens. So I guess I need to know some professional programming to be able to get some fascinating results. For example can I approximate pi up to 1000 decimals on a PC? Can I approximate e up to 1000 decimals? Things like that.
I feel I have very little information about the subject, that's why I can't explain myself very well, but I think I've somehow tried my best to tell you what my intention is, I leave the rest up to the reader that helps me what I should do. My goal is to do amateur research in numerical methods of computing math. operators by computer. What things do I need to know? What limits will I face? etc. Thanks in advance.
Technology news on Phys.org
Arbitrary Precision Arithmetic is what you need. Here you have a package for C++ since you know how to program on C++. http://www.apfloat.org/apfloat/
you can do more research on your own, the term is "arbitrary precision arithmetic". That's what Mathematica and other programs use I guess.
Here's a citation of what the website says:
ApFloat said:
Apfloat is a high performance arbitrary precision package. That means you can do calculations involving millions of digits with it.
EDIT: Perhaps you would like this one too: http://gmplib.org/
Have a look at the Wiki entry for Arbitrary Precision Arithmetic http://en.wikipedia.org/wiki/Arbitrary-precision_arithmetic
I use Mathcad as a general purpose mathematical tool and make use of its symbolic processor (either Maple or MuPad based, depending upon version) for large numbers.
There are also some interesting algorithms for generating large numbers, such as the spigot algorithm for pi. In the image below, I show one such implemented in Mathcad. It calculates each digit of pi and stores them in a vector. I then reduce the vector to a string for more convenient display (if you'd be so good as to ignore the missing decimal point between the first '3' and '1', I'd be grateful).
Related to Could you find good numerical approximations to math. problem with a PC?
1. What are the benefits of using a PC to find numerical approximations to math problems?
Using a PC allows for faster and more accurate calculations compared to manual methods. It also provides access to various software and tools that can aid in finding numerical approximations.
2. How can a PC help in finding numerical approximations for complex math problems?
A PC can handle large amounts of data and perform complex calculations with precision. It can also run simulations and algorithms to find numerical approximations for difficult math problems.
3. Are there any limitations to using a PC for finding numerical approximations?
While PCs are powerful tools, they are still limited by hardware and software capabilities. Some problems may require specialized software or hardware to find accurate numerical approximations.
4. Can a PC find numerical approximations for all types of math problems?
Yes, a PC can find numerical approximations for a wide range of math problems, including differential equations, integrals, and optimization problems. However, the accuracy of the approximation may vary depending on the complexity of the problem.
5. How can I ensure the accuracy of the numerical approximations found by a PC?
To ensure accuracy, it is important to use reliable software and double-check the results using different methods. It is also essential to have a good understanding of the problem and its mathematical principles before using a PC to find numerical approximations.
  • Quantum Physics
  • Computing and Technology
