Isambard
- 10
- 3
Don't know if this is the right forum, but I'll give it a try: If you build a bridge over a gorge that's a couple km deep the middle of the bridge would be as far away from the mountains on both sides as possible (and therefore as far away from the mountains' gravitational field as possible). Under the bridge you attach a long hollow tube which reach the bottom of the gorge, where it is attached.
On one of the mountains you drill a vertical hole, as deep as the gorge. The hole is as narrow as possible, so that light that is sent through it is as close to the mountain's gravitational field as possible.
If you're sending light with the exact same wavelength through both the hollow structure and the narrow hole that goes through the mountain, and they both travel the exact same distance, the light that travels through the mountain will have experienced more redshift than the light that goes through the hollow structure. Not much of course, the difference is so little it is practically impossible to imagine. But there will still be a difference.
Now, if you're sending a laser beam from the bottom of the gorge through a Michelson interferometer, splitting it in two, so that the left beam travel horizontally towards the hollow structure, hits a mirror so it travels vertically through the tube, and the right beam travel horizontally into the mountain, hits a mirror and travels vertically through the narrow hole. On top, both hit a mirror again and travels towards each other. Normally two beams with the same wavelength meeting each other would even each other out, but because one of them has a longer wavelength than the other, would it be possible to register the difference? If so, one could also use the same structure to send a laser from top to bottom, to measure gravitational blueshift.
Of course there would be challenges with a hollow structure exposed to wind, rain, different temperatures and so on. One could probably drill two vertical holes through a mountain, where one is much wider than the other, so that the laser in the center of the widest hole is further away from the surrounding mountain's gravitational field. But it would still be much closer than the laser sent through the hollow structure hanging from the bridge. On the plus side, it would be much easier to control the environment. And the project wouldn't face the same limitations (the depth of the gorge), even if facing the problem with rising temperatures the deeper you go (by drilling from a tall mountain plateau the temperature would rise less than if drilling from sea level).
And if a gravitational wave should pass through the planet from the right angle during one of the tests, it could perhaps be possible to register if gravitational waves have different effect on different wavelengths.
Could it be possible to build a system with this technology sensitive enough to register gravitational redshift or blueshift here on earth by comparing the two laser beams? And could other methods work just as well (even if equally challenging to build)?
