amazingjoe
- 1
- TL;DR Summary
- I am interested in having an AC outlet that can be powered by Solar. I am curious if I could use a simple and cheap DC Car Power to AC Inverter and rig the Positive / Negative leads from the Panels to the cigarette adapter. (More specific details provided below)
I'd like to take Solar Panel power output and use it to power an AC outlet on the ultra-cheap. I know a lot of people use Solar to connect to a purpose built inverter and also have a battery somewhere in the mix to provide a stable output but wondering if the following (using the assumptions below) is a possibility and if the results in more or less nominal conditions would likely be satisfactory.
Assumptions:
Question(s):
If I can have a panel that can safely (and mostly reliably when the sun is out) power electronics without a high risk of destroying the electronic I think this would be a super cool project. Solar panels can be super cheap depending on how you source them and this inverter is so cheap I have dreams of creating a cheap panel I can stick in a sunny area in the yard or even on top of an outside umbrella and running a tiny TV and maybe even a USB fan off the solar. All without a battery to save on costs.
Is this a worthwhile venture or not going to work out as I have outlined it?
Assumptions:
- Panels can be purchased (or built) to whatever the nominal output in Voltage and Amps is for the specified inverter.
- We would use a super cheap ($15) commercial car DC to AC converter shown here: Amazon Link to Converter and aim to disassemble the CAR DC connector and attach the Solar Positive/Negative to the positive/negative wires in the DC connector.
- I would like to be able to power non-high powered devices that would normally be suitable and recommended for the inverter. For example a small LCD TV that perhaps draws 18 watts.
- The device would only function consistently well when the sun light was close to nominal conditions (i.e. It may brown out when a cloud covers the sun or the panel is partially or fully in the shade or any other condition that would cause the panel to produce low amounts of power that may not be sufficient for the amount of power the device connected to the outlet may be trying to pull from the inverter.
Question(s):
- If you have Voltage and Amperage output that does not exceed the threshold that the inverter could handle should this work in theory (attaching leads from Solar + / - directly to the DC car connector +/- terminals)
- When the sun is shinning and the panels are producing nominal amounts of power would a supported device like a TV be able to run assuming there is no battery attached etc... to draw power from?
- If there is nothing in place to eliminate dips in power (i.e. No batter backup) would a device like a small television that is unable to draw the amount of power it needs (i.e. Say power dips below 18 watts for a TV that draws 18 watts) for sustained periods of time would it potentially damage the electronic?
