B Coulomb pressure and concentric spheres
The discussion centers on the electrostatic interactions between a positively charged sphere and a concentric negatively charged shell, questioning whether there is an outward pressure at the surface of the sphere or an attraction between the two. It suggests that the pressure at radius 'a' could be calculated as kqq/a²/(4πa²), decreasing to zero at radius 'b'. The conversation also posits that if 'b' were infinite, the dynamics would remain unchanged. Additionally, the problem is likened to a hydrostatics scenario, where the relationship between pressure and electric field strength is explored. Ultimately, the resolution of the field strength is sought, emphasizing the connection to hydrostatic principles.
MarkL
Suppose you have a sphere of radius a of positive charge, and a concentric shell from a to b of negative charge. The positive charge is equal to the negative charge. (non-conducting, uniform density)
Is there an outward pressure at a of kqq/a2/(4πa2) - with pressure decreasing with radius, becoming P = 0 at b.
Or, is there an attraction between the sphere and the shell --> P = 0 everywhere. The thickness of the shell does not matter. What if b was infinity?
Thanks
Do you know how to solve the problem for the field strength? Because it's the same as a hydrostatics problem with ##\nabla p(r) = -\rho \mathbf{E}(r)##. Equivalently ##\nabla(p - \rho \phi) = 0##.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
