Coulomb's Law and charge quantization
In summary, Coulomb's law states that the force between particles depends on their charge. However, charges can come in integral numbers of the electron charge magnitude or in fractional values. When dealing with clumps of charges, the charges are additive but the method of calculation depends on the size and distribution of the charges. In three dimensions, vectors must be used to represent the direction of the force.
Atomic_Sheep
Coulomb's law states that the force between particles depends on their charge. But protons and electrons have equal but opposite charges. Shouldn't the formula simply have constants with the only changes required being the signs?
In Coulomb's Law, the magnitude of the force is normally written as $$F=\frac{1}{4 \pi\epsilon_0}\frac{q_1q_2}{r^2}$$Considering that charges usually come in integral numbers of the electron charge magnitude ##e##, you could write $$F=\frac{1}{4 \pi\epsilon_0}\frac{N_1N_2e^2}{r^2}$$ for the magnitude, where ##N_1## and ##N_2## are positive integers. However, in E&M one usually models charge distributions as continuously smooth, i.e. charges can have fractional values of ##e##.
This idea is analogous to thinking of mass as being continuous without worrying about the "graininess" of atoms.
The flaw here is that you seem to think that "particles" can only be either a proton or an electron. There's nothing that says that those two are the ONLY entities that can use the label "particles". What if the particle is a composite particle, such as the nucleus of an atom? What is the force between a gold nucleus and an electron? What is the charge on an alpha particle? And wait till you hear that there are entities that can have fractional charges!
The word particles are not exclusively reserved only for protons and electrons.
Zz.
Forgot about quarks, but I haven't studied them at all.
Ok I think follow. Thanks.
A follow on question... if you have 2 protons, then it's quite trivial to calculate. What if I have 2 clumps of protons. Are the charges simply additive? 3D interactions seem much more complex than individual particles.
Yes. The charges are additive.
If you have a collection of charges, it becomes important to assign a position to the associated net charge. As long as the clumps are small compared to the distance between the clumps, you can wave your hands and treat the net charge as if it is located in the center of the clump. If the clumps are large compared to the distance between and if the charges are not distributed in a spherically symmetric manner then things get more complex.
Likes Atomic_Sheep
Coulomb's law applies to point-charges. If the clumps are small, and the distance between them is much larger than their size, then it is a very good approximation to consider the clumps as point-charges.
Otherwise, you can proceed in two ways. If the charges in the clumps are themselves point charges, you can apply Coulomb's law to each pair of charges (one in one clump, one in the other), and add the results. If the charges are in a continuous distribution, you have to use integral calculus to perform the addition.
In three dimensions, you have to use vectors, because force is a vector quantity (magnitude and direction). $$\vec F = k \frac {q_1 q_2} {r_{12}^2}\hat r_{12}$$ where r12 is the distance between q1 and q2 and ##\hat r## is unit vector that points in the direction from q1 to q2.
Likes Atomic_Sheep and jbriggs444
Thanks.
Related to Coulomb's Law and charge quantization
1. What is Coulomb's Law?
Coulomb's Law is a fundamental law in physics that describes the electrostatic interaction between electric charges. It states that the force between two point charges is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How is Coulomb's Law related to charge quantization?
Coulomb's Law is related to charge quantization because it explains how the magnitude of the force between two charged particles is determined by the amount of charge they possess. This, in turn, is connected to the concept of charge quantization, which states that electric charge exists in discrete units or multiples of a fundamental charge.
3. What is charge quantization?
Charge quantization is the principle that electric charge is always found in discrete, indivisible units. In other words, the charge of any object or particle will always be a multiple of a fundamental unit of charge, which is the charge of a single proton or electron.
4. How does charge quantization impact the behavior of charged particles?
Charge quantization impacts the behavior of charged particles by limiting the possible values of their electric charge. It also explains why charged particles cannot exist with fractional charges and why the total charge in a closed system must always be conserved.
5. Is charge quantization a proven concept?
Yes, charge quantization is a well-established concept in physics and has been confirmed by numerous experiments and observations. It is a fundamental principle in the Standard Model of particle physics and is supported by the behavior of subatomic particles and the behavior of electric fields.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
