Coulomb's Law, find the acceleration
In summary, the discussion was about calculating the acceleration of an electron released at the surface of a hypothetical Earth made only of protons. The equation used was F=(keq1q2)/r2, and the number of protons was found to be 3.57 x 1051. The resulting acceleration was found to be <something> x 1040, with some discrepancies between answers given by different people. Ultimately, it was confirmed that the answer <something> x 1040 was correct.
Dougggggg
155
Suppose the the Earth were made only of protons, but had the same surface size and mass it presently has. What would be the acceleration of an electron released at the surface? Disregard gravitation force.
F=(keq1q2)/r2
I solved for the number of protons and got something like 3.57 X 1051
Since that would be multipled by the charge of the proton, I just squared my charges and set the above number as "n." Solved for "a." My number was something times 1073 but my friend got something times 1090
Do either of these sound correct?
Ok, now I have gotten times 10 to the 40th, and 10 to the 46th. Can someone at least tell me to what power of ten their answer was? I cannot seem to get a consistent answer to save my life.
How did you got two answers? please tell me.
and mine is <something> x 1040
I don't see "n", and I don't see "a" in any of the formulas that you've provided (only one!).
How about writing a few lines showing your intermediate results?
F=ma=n(Coulomb's Law equation).
Got that answer to the 40th like 2 times in a row, I'm starting to think I am just bad at typing too many things in scientific notation.
The reason I could put in that value for n was because I was multiplying it by the charge. Either way, checked with my prof, turns out the answer <something> to the 40th was right.
Do you mean,
F = m·a = n·FCoulomb, where n is the number of protons you computed, FCoulomb is the Coulomb force between two protons separated by some distance, r, and m is the mass of ___ ... ?
Exactly, and the mass would be the electron since that is the acceleration I am trying to find.
a=0 bro, how can an electron accelerate towards protons when its released from the surface?
@ Liquidxlax
Its just a way of saying that you need not to consider the height of electron and distance b/w their centres is R of earth!
why would someone give that simple question!
______________
@ Dougggggg
This method is right!
how you got the other answer?
And especially that 1073 one!
I'm not sure, graphing calculators are not my friend, I do as many calculations as I can in my head usually before I resort to putting things in my calculator.
FAQ: Coulomb's Law, find the acceleration
What is Coulomb's Law?
Coulomb's Law is a fundamental law of physics that describes the force between two electrically charged particles. It states that the force is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
How is Coulomb's Law used to find the acceleration?
Coulomb's Law can be used to find the acceleration of a charged particle by setting the force equal to the mass of the particle multiplied by its acceleration. This equation can then be rearranged to solve for the acceleration.
What is the formula for Coulomb's Law?
The formula for Coulomb's Law is F = k * (q1 * q2) / r2, where F is the force, q1 and q2 are the charges of the two particles, r is the distance between them, and k is a constant known as the Coulomb constant.
How does distance affect the force in Coulomb's Law?
According to Coulomb's Law, the force between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance increases, the force decreases and vice versa.
What are the units for the variables in Coulomb's Law?
The units for the force (F) in Coulomb's Law are Newtons (N), the units for charge (q) are Coulombs (C), and the units for distance (r) are meters (m). The Coulomb constant (k) has units of Nm2/C2.
