Coulombs Law - Finding Force When Altering Distance
In summary: ), solving for one of the variables involves taking the derivative (d) of the equation with respect to that variable.
jemjabella42
If two charged bodies attract each other with a force of 1 Newton, with what force will they attract each other if the distance between them is reduced to one-half of its original size? (The “Newton,” abbreviated by the letter N, is the unit of force in the metric system. This is like the “pound” in the system that you are used to. Contrary to the way that most people use it, the kilogram is not a unit of force but a unit of mass.)
F = k Qq/d2
k = 9 x 10^9
I sketched out my picture then a subsequent sketch with my distance cut in half:
(+)---->1N 1N<----(-)
(+)--> <--(-) I don't know how I am supposed to figure this new force without knowing the Q values or distance! I am only guessing that since the objects are twice as close, this causes the force to double. But honestly, I don't know how to back this up numerically without additional information! Someone please tutor me to understand these concepts better.
F = k Qq/d2
k = 9 x 10^9
The force is inversely proportional to the square of the separation distance.
I still don't understand what this means. So I take d^2 (even though I don't know what d is) and then take its inverse which means d^2= square root of d^2/1?? The thing I have always hated about physics and my brain is I don't see the connections that everyone else sees... How do you know what to do when I am only given 1 value? I don't even understand what is represented by the constant k. Textbooks and handouts are spread all over my desk and I am having such a hard time understanding where all these numbers are coming from. I am really in need of some elementary explanations. I am not trying to be lazy, I have been looking at this question for 2 hours now trying to figure out how to make sense of it.
The subject of proportions and inverse proportions, etc. is usually covered in fairly basic algebra courses. This topic essentially deals with ratios.
The ratio of the new distance to the original is 1 : 1, a.k.a. 1/2
The inverse of this is  ? 
The square of that is  ? 
The ratio of the new distance is 1:1? How is that ratio equal to 1/2?
When I plug this into my equation, how to I solve from:
1N=k(Qq/d^2(1/2)) I know that as my distance gets cut in half, my 1N will expand because of the inverse relationship.
How am I expected to find the new force without a given distance??
After watching about 20 youtube videos, I think I need to take 1/(1/2)^2 and I get 4N as my new force.
I still don't understand how exactly this fits into the equation, but I am going to accept this answer with my lack of conceptual reasoning.
Can someone explain to me what would happen if I were to cut one of my charges (q) in half?
F=k (Qq(1/2))/d^2
When you're given an equation of several variables and constants (here you have F, k, Q, q, and d), and you're asked to determine how one particular variable is affected by a change in another variable, the usual approach is to take the given equation and form a ratio of the new value of the given variable to its original value. All this is done symbolically without needing to plug in actual values.
In your case you have the formula [itex] F = k \frac{Q q}{d^2} [/itex]. You're told that d is being varied in some particular way and you want to know what happens to F. So create the ratio:
[tex] \frac{F_{new}}{F_{old}} = \frac{k \frac{Q q}{{d_{new}}^2} }{k \frac{Q q}{{d_{old}}^2} } [/tex]
Simplify the right hand side by cancelling common terms and that leaves you with:
[tex] \frac{F_{new}}{F_{old}} = \frac{{{d_{old}}^2} }{{{d_{new}}^2} } = \left(\frac{{{d_{old}}} }{{{d_{new}}}}\right)^2 [/tex]
Now, the problem says that the new distance is 1/2 the old distance, and that the original force is 1N. So
[tex] \frac{F_{new}}{1N} = \left( \frac{d_{old}}{(1/2)d_{old}} \right)^2 [/tex]
Simplify again and you're left with:
[tex] F_{new} = 4N [/tex]
^ Very helpful. Thanks!
Related to Coulombs Law - Finding Force When Altering Distance
What is Coulomb's Law?
Coulomb's Law is a fundamental principle in physics that describes the force of attraction or repulsion between two charged particles. It states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
How is force calculated using Coulomb's Law?
The force between two charged particles can be calculated using the formula F = k(q1q2)/r^2, where F is the force, k is a constant, q1 and q2 are the charges of the particles, and r is the distance between them. This formula is also known as the inverse square law.
What happens to the force when the distance between two charged particles is altered?
According to Coulomb's Law, the force between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance between the particles increases, the force decreases, and vice versa. Therefore, altering the distance between two charged particles will result in a change in the force between them.
What is the relationship between force and distance in Coulomb's Law?
The relationship between force and distance in Coulomb's Law is inverse square. This means that as the distance between two charged particles decreases, the force between them increases exponentially. Similarly, as the distance increases, the force decreases exponentially.
How does Coulomb's Law relate to other laws in physics?
Coulomb's Law is similar to Newton's Law of Universal Gravitation in that both describe the force between two objects based on their masses or charges and the distance between them. However, Coulomb's Law applies specifically to electrostatic forces between charged particles, while Newton's Law applies to gravitational forces between any two objects with mass.
