Coulomb's law in three dimensions (xyz). HELP
In summary, the electric force exerted on q1 by q2 can be calculated using Coulomb's Law, which involves the charges of q1 and q2, the distance between them, and a unit vector in the direction from q2 to q1. The distance between the charges can be found using the Pythagorean theorem, and the unit vector can be calculated by dividing the displacement vector between the charges by its magnitude. The final result is a vector in the form of (Fx, Fy, Fz) that represents the electric force in the x, y, and z directions, respectively.
jezejeze
A charge q1 = 5uC is placed at (x,y,z):(1,2,-1).
A charge q2 = -2uC is placed at (x2,y2,z2):(-2,1,3).
Determine the electric force (vectorized form) exerted on q1.
F12= kQ1Q2 / r2
At first I tried finding the distance between both charges:
d = sqrt{(x2-x)2+(y2-y)2+(z2-z)2 } = sqrt{26}
I then plugged that into Coulomb's formula, and found:
F12= 5,19*10-3 N
The thing is that I am not able to get the answer into vector form...
I tried using trig:
F1X= F12 cos THETA
F1Y= F12 sin THETA
F1Z= F12 * ?
I tried drawing it.. but it's a pain in 3D.
I logically know that the force is attractive. I know that the x displacement is 3 units, and the y displacement is 1 unit, and the z displacement is 4 units.
But i still can't give my answer in the form of:
F12 = (something [tex]\vec{i}[/tex] +/- something [tex]\vec{j}[/tex] +/- something [tex]\vec{k}[/tex]) N.
If anyone could show me the light, it would be greatly appreciated!
Thanks!
The full vector form of the law is
[tex]\displaystyle \vec{F} =\frac{KQ_1Q_2 ( \vec{x_1}-\vec{x_2})}{|\vec{x_1}-\vec{x_2}|^3} [/tex]
where [tex] |\vec{x_1}-\vec{x_2}|[/tex] is the distance between the points [tex]\vec{x_1}[/tex] and [tex]\vec{x_1}[/tex].
RGV
Try this simple math:
Force in x direction = kq1q2/x^2 where x is separation in x direction. Similarly for y & z.
:eek: What happens when, say, Δx is zero (and Δy and/or Δz are not)?
I'm afraid that the vector can't be decomposed that way. Although it might be nice if it could! :smile:
Oh Sorry, my mistake:cry:
Thanks gneill
So all I need to do is plug in the numbers in the formula .. and that's it ?! No angles and vector stuff... !
Thanks alot!
RGV
Thanks alot!
Well, the "vector stuff" is still there, but it's in a form that requires very little in the way of puzzling out directions, angles, components, and so forth. It's plug-and-play physics!:wink:
well after a while of trying with the formula stated by RGV in an earlier post, and still not coming to the correct answer.. ( I guess I was doing something wrong.. with a P&P formula..!).. I found a much more logical way!
Just need to use the distance between q1 and q2 which is sqrt{26}, use it in Coulomb's simple formula, and then multiply by the unit vector
vec{Q2Q1}:( 3/sqrt{26}{i} + 1/sqrt{26}{j} -4/sqrt{26}{k})
and then voilà, you get:
[tex]\vec{F}[/tex] 12=(-3,05{i} - 1,02{j}+ 4,07{k}) * 10-3 N
Anyways, thanks for everyone's help!
[tex]\vec{Q2Q1}[/tex]:( 3[tex]\vec{i}[/tex]+1[tex]\vec{j}[/tex]-4[tex]\vec{k}[/tex])
[tex]\vec{F}[/tex] 12=(3,05 ; 1,02 ; 4,07) * 10-3 N
You're attempting to carry out what Ray's formula prescribes, but doing it in two parts. You've found the distance (well, the square of the distance): |x1 - x2|2 = 26m2 and used that in a scalar version of Coulomb's Law. Then you took that as a magnitude and (wanted to) multiply by a unit vector in the appropriate direction. But something looks fishy with your unit vector.
It should be:
[tex] u = \frac{ \vec{x_1} - \vec{x_2}}{|\vec{x_1} - \vec{x_2}|} [/tex]
and that should yield something like (0.588, .196, -0.784)m as a unit vector.
Rewriting the overall calculation and making these "tasks" more obvious,
[tex] \vec{F} = K \frac{Q1 Q2}{|\vec{x_1} - \vec{x_2}|^2} \cdot \frac{ \vec{x_1} - \vec{x_2}}{|\vec{x_1} - \vec{x_2}|} [/tex]
You should recheck your unit vector math.
yeah
||Q2Q1|| = sqrt {32+12+(-4)2 } = sqrt{26}
so the unit vector is:
3/sqrt{26} = 0.588i
1/sqrt{26} = 0.196j
-4/sqrt{26}= -0.784k
I just misinterpreted the meaning of the '' | '' in the formula as being absolute values instead of the '' || '' of being the ''norme'', or magnitude you call it in English.
(I'm from Quebec, Canada, so everything is in french, and for us magnitude is written:
|| x1 - x2 ||, and absolute value is | x1 - x2 |. )
But anyways the answer coincides, so everything is a-ok! Thanks. And yes my vector math sucks!
FAQ: Coulomb's law in three dimensions (xyz). HELP
What is Coulomb's Law in three dimensions?
Coulomb's Law in three dimensions is an equation that describes the electrostatic force between two charged particles in three-dimensional space. It takes into account the distance and direction between the particles, as well as the magnitude of their charges.
How is Coulomb's Law represented in three dimensions?
In three dimensions, Coulomb's Law is represented as F = k(q1q2/r^2) * r^, where F is the force between two particles, k is the Coulomb constant, q1 and q2 are the charges of the particles, and r is the distance between them.
What is the Coulomb constant?
The Coulomb constant, represented by the symbol k, is a proportionality constant used in Coulomb's Law. It has a value of 8.988 x 10^9 Nm^2/C^2 in a vacuum.
How does distance affect the force in Coulomb's Law in three dimensions?
According to Coulomb's Law in three dimensions, the force between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance between the particles increases, the force decreases.
Can Coulomb's Law be applied to non-point charges in three dimensions?
Yes, Coulomb's Law in three dimensions can be applied to non-point charges, as long as the charges can be approximated as small enough to be considered point charges. This is because Coulomb's Law assumes that the charges are concentrated at a single point.
