Coulomb's Law on a line again.
In summary, you need to find d\textbf{E} from dE, and integrate to find \textbf{E}. The x-component of d\textbf{E} is dE_x=-dE\sin\theta while the y-component is dE_y=-dE\cos\theta. E_y=Esin(45), so E=220 sin(45)+155.56.)
exitwound
292
Coulomb's Law on a line...again.
[tex]E=\frac{kQ}{d^2}[/tex]
I've been working on this one for three days now and can't come up with a valid answer.
I've broken this problem up into two sections, one for the upper ring segment, and one for the bottom ring segment.
Upper Segment
[tex]E=\frac{kQ}{d^2}[/tex] \\Coulomb's Law
[tex]dQ=\lambda ds[/tex] \\charge on the differential
[tex]ds= R d\Theta[/tex] \\area of the differential
[tex]dE=\frac{kdQ}{d^2}[/tex]
[tex]dE=\frac{k\lambda R d\Theta}{R^2}[/tex]
[tex]E=\int_0^{\pi /2}dE[/tex] \\Electric field is the sum of all the differential electric fields.
[tex]E=\int_0^{\pi /2}\frac{k\lambda R d\Theta}{R^2}[/tex]
[tex]E=\frac{k\lambda R}{R^2}\int_0^{\pi /2}d\Theta[/tex]
[tex]E=\frac{k\lambda}{R}\int_0^{\pi /2}d\Theta[/tex]
[tex]E=\frac{k\lambda}{R}(\pi/2 - 0)[/tex]
[tex]E=\frac{k\lambda \pi}{2R}[/tex]
[tex]\lambda = \frac{Q}{L}[/tex]
[tex]\lambda = \frac{Q}{\frac{R\pi}{2}}[/tex]
[tex]E=\frac{2kQ \pi}{2\pi R^2}[/tex]
[tex]E=\frac{kQ}{R^2}[/tex]
[tex]E=\frac{(9E9)(5.5E^-12)}{(.0150)^2}=220 N/C[/tex]
This is the Electric field generated by the upper segmant of the ring. The angle at which it points is 45 degrees below horizon, or 315 degrees.
Lower Segment
The lower segment is identical. The same charge magnitude exists on the ring. The distance is the same to the ring. The only difference is the direction of the resulting force because the charge on the ring is negative. Therefore, the Electric field is also 220 N/C but its direction is towards the ring, or 135 degrees.
Both Segments
The resulting forces added together produce a direction directly down, or 270 degrees from horizontal. Since we have canceling x-components of the two forces, the y-components are all that matter.
[tex]E_y=Esin(45) = 220 sin(45) = 155.56[/tex] \\Ey component of upper half.
[tex]E_y=Esin(45) = 220 sin(45) = 155.56[/tex] \\Ey component of lower half.
Added together, is 311.13 N\C in the 270 degree direction.
What am I doing wrong??
Well, you have [itex]dE=\frac{\lambda k d\theta}{R}[/itex], but just like the total field, each infinitesimal portion of the field will be a vector, so you need to find [itex]d\textbf{E}[/itex] and integrate that in order to find [itex]\textbf{E}[/itex]...you will find that the x-component integrates to zero, consistent with your answer to (b) and the y component integrates to something negative
so you're saying I need to do this?
[tex]dE=\frac{\lambda k cos \Theta d\Theta}{R}[/tex]
Sort of, [itex]dE\cos\theta[/itex] will give you a component of [itex]d\textbf{E}[/itex], but which component (+x,+y,-x,or -y component)?
I'm lost then. I have no idea.
Color in a small section of your wire (in the upper region) and call that section [itex]dQ[/itex], label the angle [itex]\theta[/itex] however you want, and draw a vector from [itex]dQ[/itex] to [itex]P[/itex]...Colulomb's law tells you that the field [itex]d\textbf{E}[/itex] due to [itex]dQ[/itex] points along that vector right? What component of that will point in the x-direction? How about the y-direction?
This is what I've been doing. You should see my pages and pages of pictures.
Upper section:
(I'm taking Theta to be from the +y axis towards the -x axis)
E points in the 315 degree direction.
The y-component of that would be Ecos(Theta).
The x-component of that would be Esin(Theta).
How about I show you one of mine instead...
http://img199.imageshack.us/img199/7655/efield.th.jpg
You should see clearly, that the x-component of [itex]d\text{E}[/itex] is [itex]dE_x=dE\sin\theta[/itex] while the y-component is [itex]dE_y=-dE\cos\theta[/itex]...right?
Indeed. I left the negative off the cos because I knew the direction. My picture looks identical to yours.
Okay, so integrate now...what do you get for the components of the field due to the upper section of wire?
[tex]E=\int_0^{\pi/2}\frac{k\lambda (-cos\Theta) d\Theta}{R}[/tex]
[tex]E=\frac{-k\lambda}{R}\int_0^{\pi/2}cos\Theta d\Theta[/tex]
[tex]E=\frac{-k\lambda}{R}(sin\Theta|_0^{\pi/2})[/tex]
[tex]E=\frac{-k\lambda}{R}(1-0)[/tex]
[tex]E=\frac{-k\lambda}{R}[/tex]
Well that's [itex]E_y[/itex]...you know from symmetry that [itex]E_x[/itex] from the upper section should cancel [itex]E_x[/itex] from the lower section, so you don't have to calculate each [itex]E_x[/itex] but you probably shuld anyways, so that you can check that the two do in fact cancel (if they don't then you know you've done something wrong)
Anyway, what about [itex]E_y[/itex] from the lower segment...what do you get for that?
[tex]E=\int_0^{\pi/2} dE sin(\Theta)[/tex]
[tex]E=\frac{k\lambda}{R}\int_0^{\pi/2}sin\Theta d\Theta[/tex]
[tex]E=\frac{k\lambda}{R}(-cos\Theta|_{\pi/2}^{\pi})[/tex] \\\\or from 0-->pi/2
[tex]E=\frac{k\lambda}{R}(0-1)[/tex]
Which is the same magnitude as the upper half, which makes sense.
(I have to get to bed. I'll check back in the morning. Thanks for the help so far.)
Right, so the total field is____?
[tex]
E=\frac{-2k\lambda}{R}
[/tex]
where [itex]\lambda[/itex] = Q/L where L= R*pi/2
Right, now plug in the numbers...what do you get for |E| ?
-280.14 n/c
Related to Coulomb's Law on a line again.
1. What is Coulomb's Law?
Coulomb's Law is a fundamental law of physics that describes the electrostatic force between two charged particles. It states that the force of attraction or repulsion between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How is Coulomb's Law related to electricity?
Coulomb's Law is directly related to electricity, as it explains the force between two electrically charged particles. It is one of the fundamental laws that govern the behavior of electric charges and is essential for understanding the behavior of electrically charged objects.
3. What is the mathematical formula for Coulomb's Law?
The mathematical formula for Coulomb's Law is F = k * (q1 * q2) / r^2, where F is the force between two charged particles, k is the Coulomb's constant (8.99 x 10^9 N*m^2/C^2), q1 and q2 are the charges of the particles, and r is the distance between them.
4. What is the unit of measurement for Coulomb's Law?
The unit of measurement for Coulomb's Law is Newtons (N), which represents the force between two charged particles. It can also be expressed in terms of Coulombs (C), which is the unit of electric charge, and meters (m) for distance.
5. How does Coulomb's Law change with distance?
According to Coulomb's Law, the force between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance between two charged particles increases, the force between them decreases. Therefore, the force of attraction or repulsion decreases as the distance between two charged particles increases.
