Coulomb's Law Problem magnitude and direction
In summary: Only 2 or 3 is appropriate for this problem.In summary, the magnitude and direction of the electric field at a point midway between a -9.0 µC and a +6.0 µC charge 3.0 cm apart is -120,000 N/C, pointing towards the negative charge. The field at this point is the sum of the individual fields from each charge, taking into account the direction of each field.
swede5670
78
What are the magnitude and direction of the electric field at a point midway between a -9.0 µC and a +6.0 µC charge 3.0 cm apart? Assume no other charges are nearby.
Fe= {K(q1)(q2)}/d^2
k = (8.99 x 10^9)
First I converted the µC to C =
-9 µC = -.000009 C
6 µC = .000006
Then convert 3 cm to mm = .03
(8.99 x 10^9) (-.000009) ( .000006 ) = -.48546
-.48546/d^2
-.48546/ .03
-539.4
My final answer is -539.4 but I know its wrong, can anyone tell me what I did incorrectly?
Fe= {K(q1)(q2)}/d^2
k = (8.99 x 10^9)
-9 µC = -.000009 C
6 µC = .000006
-.48546/d^2
-.48546/ .03
-539.4
You found the Force between the 2 charges. The question asks for the field at a point half way between the two.
F = q*E
What you want is E, given by
E = kq/r2
Your distance is .015 m to each. And remember these are vectors and when you add the field at the mid point you want to take care with what direction the field of each would be pointing.
What Q value would you use though?
For E you are using the q of the charges you are measuring. 1 term will be the field from the 6 µC charge and the other the 9 µC.
So there will therefore be two answers?
I'm confused by what your saying
"For E you are using the q of the charges you are measuring."
I realize this, but do I need to set up two equations then? Or do I have to add the charges?
The E-field at any point will be the ∑ of the E from all charges
so sigma is the sum right?E = k(6x10^-6)/r2
is added with:
E = k(-9*10^-6)/r2
once I've added these two Es up is that my final answer?
E = k(6x10^-6)/r2
is added with:
E = k(-9*10^-6)/r2
Sort of. But you must be careful with the sign. Since one charge is plus and the other minus, in between the charges then the field magnitudes both add and point toward the negative charge.
{(8.99*10^9)(-9*10^-6)}/.015^2 = -359,600,000
{(8.99*10^9)(6*10^-6)}/.015^2 = 239, 733, 333
Adding these two up
-359,600,000 + 239, 733, 333 = -119, 866, 666
-119, 866, 666 N/C seems ridiculous, what did I do here?
Adding these two up
Not quite.
As I said several times, these are vectors. As it turns out both vectors are pointing in the same direction.
To determine the |F| then you simply add the |Fq1| + |Fq2|.
The - sign means that the Force points toward a charge and the + sign means that the field points away from the charge. Draw a picture nd you will see that at the mid point for these charges the E-field from both is pointing in the same direction ... hence the magnitudes add at that point.
Oh, and your answers have too many significant figures.
Related to Coulomb's Law Problem magnitude and direction
1. What is Coulomb's Law?
Coulomb's Law is a fundamental law in physics that describes the electrostatic interaction between two charged particles. It states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How do I calculate the magnitude and direction of the force using Coulomb's Law?
To calculate the magnitude of the force, you can use the formula F = k * (q1 * q2)/r^2, where k is the Coulomb constant (9 x 10^9 Nm^2/C), q1 and q2 are the charges of the particles, and r is the distance between them. The direction of the force can be determined by the electric field lines, which point in the direction of the force from positive to negative charges.
3. Can Coulomb's Law be applied to point charges only?
No, Coulomb's Law can also be applied to extended objects with a distribution of charge, as long as the distance between the objects is much greater than the size of the objects. In this case, the total charge of each object can be used in the calculation.
4. How does the distance between the charged particles affect the force?
The force between two charged particles is inversely proportional to the square of the distance between them. This means that as the distance increases, the force decreases. If the distance is doubled, the force decreases by a factor of four.
5. What are the units of the force calculated using Coulomb's Law?
The units of the force are Newtons (N), which is the unit of force in the International System of Units (SI). This is because the Coulomb constant has units of Nm^2/C^2 and the charge has units of Coulombs (C), resulting in N as the final unit.
9K
10K
9K
