Couloumb's Law 3 charges on a line
In summary, the problem involves three point charges (q1 = 6.36 µC, q2 = 1.56 µC, and q3 = -1.84 µC) positioned along a straight line with separation distances (d1 = 3.00 cm and d2 = 2.00 cm). The task is to calculate the net electric force on each charge. The individual forces on q2 from q1 and q3 are calculated using Coulomb's law and then added to get the force on q2. The work done so far shows the force on the middle charge to be -187.8 N.
PatrickGeddes
I did this problem just the way I took notes on it in class and keep coming up with the wrong answer. Please help I've spent nearly 2 hours on this one simple problem. Thanks.
Problem: Three point charges lie along a straight line as shown in the figure below, where q1 = 6.36 µC, q2 = 1.56 µC, and q3 = -1.84 µC. The separation distances are d1 = 3.00 cm and d2 = 2.00 cm. Calculate the magnitude and direction of the net electric force on each of the charges.
You have to show your work so far.
Ok sorry, first time using the site. I did F of q1 on q2 is ((8.99x10^9) x .00000636 C x .00000156 C)/.0009 m=99.10576 N and F of q3 on q2 is ((8.99x10^9) x -.00000184 C x .00000156 C)/.0016 m=-286.72 N. Then for the Force on the middle charge I just added them together to get -187.8 N.
Is this enough work so far?
First of all, don't get discouraged! Coulomb's Law can be tricky, but with some practice and understanding of the concepts, you will be able to solve these types of problems easily.
To solve this problem, we will use Coulomb's Law, which states that the magnitude of the electric force between two point charges is directly proportional to the product of the charges and inversely proportional to the square of the distance between them. Mathematically, it can be written as F = k(q1q2)/r^2, where k is the Coulomb's constant (9x10^9 Nm^2/C^2), q1 and q2 are the charges, and r is the distance between them.
Now, let's begin by finding the net electric force on q1. We will consider the forces from q2 and q3 separately and then add them together.
From q2, the distance is d1 = 3.00 cm = 0.030 m. Plugging in the values, we get F1 = k(q1q2)/d1^2 = (9x10^9)(6.36x10^-6)(1.56x10^-6)/(0.030)^2 = 1.68x10^-5 N.
Note that this force is directed towards the right, as q1 and q2 have opposite charges and therefore attract each other.
From q3, the distance is d2 = 2.00 cm = 0.020 m. Plugging in the values, we get F2 = k(q1q3)/d2^2 = (9x10^9)(6.36x10^-6)(-1.84x10^-6)/(0.020)^2 = -3.39x10^-5 N.
Note that this force is directed towards the left, as q1 and q3 have like charges and therefore repel each other.
Now, to find the net force on q1, we simply add these two forces together: Fnet = F1 + F2 = 1.68x10^-5 - 3.39x10^-5 = -1.71x10^-5 N. This means that the net force on q1 is directed towards the left with a magnitude of 1.71x10^-5 N.
Similarly, we can find the net force on q2 and q3
Related to Couloumb's Law 3 charges on a line
1. What is Couloumb's Law?
Couloumb's Law is a fundamental law of physics that describes the force between two charged particles. It states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How does Couloumb's Law apply to 3 charges on a line?
In the case of 3 charges on a line, Couloumb's Law can be used to calculate the net force on one of the charges due to the other two charges. The force on a charge will depend on the distance and magnitude of the other two charges, as well as the distance between them and the charge in question.
3. Can Couloumb's Law be used to calculate the forces between more than 3 charges?
Yes, Couloumb's Law can be applied to any number of charges. However, the calculations can become more complex as the number of charges increases.
4. How does the direction of the charges affect the force calculated using Couloumb's Law?
The direction of the charges does affect the force calculated using Couloumb's Law. If the charges are of the same sign, the force will be repulsive, while if they are of opposite signs, the force will be attractive. Additionally, the direction of the force will depend on the relative positions of the charges.
5. What are the units for the constants used in Couloumb's Law?
The units for the constant of proportionality, k, in Couloumb's Law are Nm²/C². The units for charge are Coulombs (C) and the units for distance are meters (m). When these units are used in the equation, the resulting unit for force is Newtons (N).
10K
9K
10K
36K
40K
