Coulumbs, Joules and their relation in electronics
In summary, the conversation discusses the concepts of coulombs, joules, electric current, voltage, and resistance in electricity. Coulombs are a unit of charge and joules are a unit of work. Electric current is the movement of charge, typically measured in coulombs per second. Voltage is the amount of work produced per unit of charge, and resistance is the back-force on the current. The conversation also mentions Joule's law, which relates power (measured in watts) to current and voltage. The relationship between these concepts can be better understood through further reading and practice.
Tryp
Hello,
I'm bit confused about relation of the two, would be really great if someone explained it.
So the coulumb is said to be the force between two charges(repelling or attracting), which depends
on quantity of charges and their distance.
Joule is said to be force that is needed to move object of 1kg by 1 metre in second
So, electric current , for example, 1 Ampere, is when 1 Coulumb travels from point A to point B in 1 second, which is coulumbs per second (C/s)
One Volt, is how many Joules one Coulumb transfers(J/C). Here I don't understand
how exactly force between charges transfers energy needed for work ?
And last thing is resistance in electricity - By Ohms law R= V/I,
in other terms that is
````J
````C
````C
````S
and that equals to J*S ( I tried using math symbols but the code is messing it up)
So basically resistance in electric circuit is how much joules it does not let thru every second?
I'm confused.
I suggest you do some basic reading, for each of the terms confusing you, but maybe I can clear up parts. After a while they'll make sense but you have to take time at first to read and think about each...and their relationship.
Coulomb is a quantity of charge; a moving charge constitutes a current.
for q = it, q coulombs, i current and t time.
A joule is a unit of work...one Newton meter where a Newton is a unit of force...a mechanical view is
W = Fd, w is work, F is force and d distance.
and an electrical perspective:
In P = IE = I2R = E2/R are versions of Joule's law in volt-amps, joules/sec and/or watts.
Power, as you can see, is work per unit time...the rate at which work is done.
I always parallel (pardon the pun) current with speed. Current is C/s, whereas speed is m/s (easy concept). Current is just how much charge moves through a wire per unit of time.
Voltage always tend to be a harder concept. My teacher attempted to explain it as compared to pressure in a water pipe, however I'm not sure I entirely agree with it (but I'll reserve further judgement).
Voltage of course is J/C, which is a Nm/C... So it's just amount of "work" produced in ratio with the charge of the wire.
It's a tough concept, but I found as I worked with these units more and more my understanding of them improved with time.
As for resistance the units don't help much (Js/C^2), but basically I think of it as the back-force on the current (like resistors along the path)
Thanks guys, that made things a bit clear.
Yeah I have heard it too, that it's like if there's pipe filled with water and you add, say, 1 litre to one end, you will also get 1 litre out of the other end, but if there's load or resistance, the energy that was added will be absorbed by it...something like that.
E is energy or Joule in other words?
Related to Coulumbs, Joules and their relation in electronics
1. What is the difference between Coulombs and Joules?
Coulombs and Joules are both units of measurement in the field of electronics. Coulombs measure electric charge, while Joules measure energy.
2. How are Coulombs and Joules related in electronics?
In electronics, Coulombs and Joules are related through the concept of electrical potential energy. One Coulomb of charge moving through an electric potential of one Volt will have one Joule of energy.
3. Can you convert between Coulombs and Joules?
Yes, you can convert between Coulombs and Joules using the formula: 1 Joule = 1 Coulomb * 1 Volt.
4. How are Coulombs and Joules used in circuit analysis?
Coulombs and Joules are used in circuit analysis to calculate the energy stored in capacitors and to understand the flow of electricity in a circuit.
5. Are Coulombs and Joules important in everyday electronics?
Yes, Coulombs and Joules are important in everyday electronics as they help to measure and understand the behavior of electricity and energy in circuits, which are essential for devices such as smartphones, computers, and household appliances.
  • Electromagnetism
  • Electromagnetism
