MHB Countably Dense Subsets in a Metric Space .... Stromberg, Lemma 3.44 .... ....
Math Amateur
MHB
I am reading Karl R. Stromberg's book: "An Introduction to Classical Real Analysis". ... ...
I am focused on Chapter 3: Limits and Continuity ... ...
I need help in order to fully understand the proof of Lemma 3.44 on page 105 ... ... Lemma 3.44 and its proof read as follows:
In the above proof by Stromberg we read the following:
" ... ... Also, if $$x \in X$$ and $$\epsilon \gt 0$$, it follows from (2) that $$B_\epsilon (x) \cap A \supset B_{ 1/n } (x) \cap A_{ 1/n } \neq \emptyset$$ , where $$1/n \lt \epsilon$$ ... ... "My question is as follows:
Can someone please demonstrate rigorously why/how it is the case that $$B_\epsilon (x) \cap A \supset B_{ 1/n } (x) \cap A_{ 1/n }$$ ... ... ?
*** EDIT ***
After a little reflection this issue may be straightforward ... ... Wish to show formally that $$B_{ 1/n } (x) \cap A_{ 1/n } \subset B_\epsilon (x) \cap A $$We need to show that $$x \in B_{ 1/n } (x) \cap A_{ 1/n } \Longrightarrow x \in B_\epsilon (x) \cap A$$But ... leaving out details ... we have ...$$x \in B_{ 1/n } (x) \cap A_{ 1/n }$$$$\Longrightarrow x \in B_{ 1/n } (x) \text{ and } x \in A_{ 1/n }$$ $$\Longrightarrow x \in B_{ \epsilon } (x) \text{ and } x \in A$$$$\Longrightarrow x \in B_\epsilon (x) \cap A$$
Is that correct?
=======================================================================================Help will be appreciated ...
Peter
Yes, it is straight forward. In a metric space, where we have a notion of "d(x,y)", the distance between points x and y, a "ball", "$B_\epsilon(x)$" where x is a point of the metric space and $\epsilon$ is a positive real number, is defined as the set of all points, y, in the metric space such that $d(x,y)< \epsilon$. Geometrically it is the interior of the sphere with center at x and radius $\epsilon$.
Geometrically, $B_x(1/n)$ is the ball with center x and radius 1/n while $B_x(\epsilon)$ is the ball with center x and radius $\epsilon$. If $1/n< \epsilon$ then the two balls have the same center but $B_x(1/n)$ has the smaller radius so is completely contained in $B_x(\epsilon)$.
Algebraically, any point, y, ih $B_x(1/n)$ has distance from x, d(x,y)< 1/n. But $1/n< \epsilon$ so $d(x,y)< 1/n< \epsilon$. Since $d(x,y)< \epsilon$, y is also in $B_x(\epsilon)$. Since y could be any point of $B_x(1/n)$, $B_x(1/n)\subset B_x(\epsilon)$.
By the way, in your title, "Countably Dense Subsets in a Metric Space", "countably" is an adverb modifying "dense". That makes no sense- there is no such thing as "countably dense". You should have "Countable Dense Subsets in a Metric Space" where "countable" is an adjective modifying "subset".
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
