scottthomascarter
- 5
- 1
You may already be doing this, but be sure to include the motor's moment of inertia along with the disc.scottthomascarter said:the objective is to reduce the Disc B mass and compensate by increasing the spin rate or altering the moment of inertia (via geometry).
berkeman said:You may already be doing this, but be sure to include the motor's moment of inertia along with the disc
It looks like you are using the same type of motor for each one, so you might just be able to determine it experimentally by finding the spin rate needed for one motor without a disc to balance the other motor with a disc with a known MOI...scottthomascarter said:I'll dissect a motor to get that internal geometry and make my best estimate on it.
If I understand what you are saying, I don't think it will work. The rotating propeller/impeller is using torque to accelerate the air mass downward to generate lift, and you can't counter that constant torque with just a counter-rotating disc. You would need to continually be accelerating that disc to be getting a counter-torque, and that's only going to work for a few seconds at best.scottthomascarter said:But the real result we will be going for will be in a flying vehicle with a spinning impeller for downward thrust, and we will be counteracting that rotational force using a counter-rotating mass of a very different geometry (so a different MOI).
The flight control computer achieves that at millisecond intervals using on board accelerometers and gyros. DC brushless motors (the kind used in most drones currently) respond equally efficiently (i.e. almost instantaneously) to Electronic Speed Controller inputs based on sensor feedback. But that's not the issue, the principle is sound. I just need to quantify that principle to predict how much energy needs to be planned for. I know it's not as simple as massA x angular velocityA = massB x angular velocityB if those masses are different "shapes". That's where the factor of the second moment of area comes in (I think). I just don't know how, and that's what I'm looking for.berkeman said:If I understand what you are saying, I don't think it will work. The rotating propeller/impeller is using torque to accelerate the air mass downward to generate lift, and you can't counter that constant torque with just a counter-rotating disc. You would need to continually be accelerating that disc to be getting a counter-torque, and that's only going to work for a few seconds at best.
Drones use counter-rotating props to avoid yaw issues.scottthomascarter said:(the kind used in most drones currently)
