Counting Outcomes - Probability Question
In summary, the conversation discusses a game where Z wins if two heads in succession are encountered and loses if after 5 flips there are not two heads in succession. The probability of Z winning is 5/8 and the probability of both games having the same outcome is unknown. The conversation also mentions confusion with probability questions and a possible error in the calculation of outcomes.
Legendre
62
Z plays a game where independent flips of a coin are recorded until two heads in succession are encountered.
Z wins if 2 heads in succession occurs.
Z loses if after 5 flips, we have not encounter two heads in succession.
1) What is the probability that Z wins the game?
2) Suppose coin is fair. Z plays twice. What is the probability that both games have the same outcome?
N.A.
I get very confused by questions related to probability. :(
There are 5 flips at most so the sample space has 2^5 = 32 possible outcomes. When seen as 5 "slots", as long as two adjacent slots are filled with H (for "heads") then Z wins.
P(Z wins) = 1 - P(Z loses)
Let X = number of heads. Then, Z loses when X = 1. Z loses in some cases when X = 2,3.
X = 1 : There are 5 possible outcomes.
X = 2 : The two heads are either 1 slot apart (3 choose 1 = 3 outcomes) or 2 slots apart (2 choose 1 = 2 outcomes) or 3 slots apart (1 outcome)
X = 3 : The three heads need to be in slot 1,3,5 => 1 outcome.
So total outcome that results in a loss = 1 + 5 + 3 + 2 + 1 = 12.
Therefore, P(Z win) = 1 - 12/32 = 20/32 = 5/8.
Question : Is this method correct? Are there "cleaner" methods? I have no idea how to start part 2.
Are you sure you have accounted for all 32 outcomes?
Doh!
X = 0.
Thats one more outcome. :(
But my approach is correct?
Yes.
FAQ: Counting Outcomes - Probability Question
What is the difference between outcomes and events in probability?
The outcomes are all the possible results of an experiment, while an event refers to a specific subset of outcomes that we are interested in. For example, in a coin toss experiment, the outcomes are either "heads" or "tails", while an event could be "getting heads".
How do you calculate the probability of an event?
The probability of an event is calculated by dividing the number of favorable outcomes by the total number of possible outcomes. For example, if we roll a dice and want to find the probability of getting an even number, we divide the number of even numbers (3) by the total number of outcomes (6), which gives us a probability of 3/6 or 1/2.
What is the difference between theoretical probability and experimental probability?
Theoretical probability is based on mathematical calculations and assumes that all outcomes are equally likely. On the other hand, experimental probability is based on actual experiments and takes into account any variations or biases in the outcomes. Experimental probability tends to be more accurate in real-world situations.
What is the difference between independent and dependent events?
Independent events are events where the outcome of one event does not affect the outcome of another event. For example, rolling a dice and flipping a coin are independent events. On the other hand, dependent events are events where the outcome of one event does affect the outcome of another event. For example, drawing two cards from a deck without replacement is a dependent event as the outcome of the first draw affects the possible outcomes of the second draw.
How do you use combinations and permutations in probability?
Combinations and permutations are used to calculate the number of ways in which a specific event can occur. Combinations are used when the order does not matter, while permutations are used when the order does matter. For example, if we have 5 different colored balls and want to choose 3 of them, we would use combinations because the order of the chosen balls does not matter. However, if we want to choose 3 balls in a specific order, we would use permutations.
