MHB Counting shortest paths in a non-directed graph using BFS
  • Thread starter Thread starter evinda
The discussion focuses on finding an algorithm to calculate the number of shortest paths between two nodes, v and u, in a non-directed graph G. The proposed solution involves using Breadth-First Search (BFS) to traverse the graph. During the BFS process, as nodes are added to the queue, the algorithm also counts the number of shortest paths leading to each node. This approach is suggested to operate within the desired time complexity of O(n + m), where n is the number of vertices and m is the number of edges. Participants are encouraged to implement the algorithm and evaluate its effectiveness and performance.
evinda
MHB
Hello! (Wave)
A non-directed graph $G=(V,E)$ and two nodes $v$ and $u$ of $G$ are given. Give an algorithm that calculates the number of shortest paths $v-u$ in $G$. (The algorithm doesn't have to print all the paths, just how many exist.) The algorithm should run in time $O(n+m)$ for a graph with $n$ vertices and $m$ edges. Is it like that?
We apply BFS. At the point where we add the nodes in the queue, we calculate also the number of nodes.
Technology news on Phys.org
What do you think? Have you tried implementing it to see if it sort of works, try and measure the complexity, ...?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
