Counting the electrons of a coordination complex
In summary, the rhodium complex has a total electron count of 18, with the iodide ligands donating two electrons each. It is a coordinatively unsaturated complex due to the limited number of valence electrons on the central rhodium atom.
CrimpJiggler
149
Heres the Monsanto process:
I can't figure out how to determine the electron count for these rhodium complexes. Starting with the one at the top. Heres how I count its electrons: rhodium is a group 9 element so it has 2s electrons and 7d electrons which means it has 9 out of 18 valence electrons to begin with. The 2 CO ligands add an extra 4 electrons, bringing the total to 13. I'm a bit confused about how the iodide ligands work, do they also donate 2 electrons each? If so, that brings the electron count to 17. The ion has a charge of -1, bringing the total electron count to 18. How can this be a coordinatively unsaturated complex? If you add 2 more ligands to it then you end up with an electron count of 22.
Chemistry news on Phys.org
Your process for counting the electrons in the rhodium complex is correct. The iodide ligands do indeed donate two electrons each, bringing the total electron count to 17. This is a coordinatively unsaturated complex because it does not have a full octet of electrons around the central atom. In order for the complex to become saturated, two more ligands would need to be added, which would bring the electron count up to 22. The key to understanding why this is an unsaturated complex is that the central atom, rhodium, only has nine valence electrons. The two CO ligands donate four electrons, leaving five electrons to be donated by the other three ligands. With only three additional ligands, there is no way to donate the remaining five electrons, meaning that the complex is coordinatively unsaturated.
Related to Counting the electrons of a coordination complex
1. How do you count the electrons of a coordination complex?
Counting the electrons of a coordination complex involves determining the number of valence electrons contributed by each ligand and the central metal ion. This can be done by looking at the electronic configuration of each element and considering any charges present.
2. What is the significance of counting the electrons of a coordination complex?
Counting the electrons is important in understanding the chemical and physical properties of coordination complexes. It can help predict the geometry, magnetic properties, and reactivity of the complex.
3. What is the role of ligands in electron counting of a coordination complex?
Ligands are molecules or ions that surround and bind to the central metal ion in a coordination complex. They contribute electrons to the complex and their electronic configuration must be taken into account when counting the total number of electrons.
4. How does the coordination number affect the electron count in a coordination complex?
The coordination number, which refers to the number of ligands attached to the central metal ion, directly affects the electron count. The more ligands present, the more electrons will be contributed to the complex.
5. Are there any exceptions to the rules of counting electrons in coordination complexes?
While there are general rules for counting electrons in coordination complexes, there can be exceptions due to factors such as the presence of multiple oxidation states for the central metal ion or the presence of bridging ligands. It is important to consider the specific structure and composition of the complex when counting electrons.
14K
  • Chemistry
  • Electromagnetism
