Coupled nuclear decay rate equations
The discussion focuses on solving a coupled nuclear decay rate equation involving a decay chain N1 -> N2 -> N3, where N2 is produced from N1 through a reaction rather than decay. The rate equation for N2 is expressed as dN2(t)/dt = at - R2N2(t), with R2 being the decay rate from N2 to N3. The challenge arises from the coupling of the increase in N2 with its decay, complicating the solution. A simplification is suggested by treating N2's production as constant, leading to a first-order linear differential equation. The conversation concludes with advice to formulate a separate equation for the decay of N3.
jmz34
If we have the following partial decay chain:
N1 -> N2 -> N3 where N1 is the number of nuclei of species 1, etc.
and N1 -> N2, not via a decay but by the reaction such as N1 + neutron -> N2 + photon
and we know this rate of formation of N2, say 'a'.
I then get the following rate equation:
dN2(t)/dt=at-R2N2(t)=at-R2N2(0)exp(-R2t) where R2 is the decay rate from N2->N3
This would be simple to solve if the RHS wasn't coupled. By this I mean in a certain time, dt, there will be an increase in N2, dN2, which will couple into the N2(0) term and subsequently decay.
How would I go about solving this? Thanks.
If you're assuming that the rate of production of N2 is constant (i.e., the supply of N1 is constant) then you're really only dealing with one substance, N2, and its rate of production versus its rate of decay. So, dropping the "2" and just calling it "N",
dN/dt = a - rN
where r is the decay rate of substance N. This is a first order linear differential equation, namely
N' + rN - a = 0
Also I think your second equation seems to be wrong, I think I can see where you mistakenly got it from.
Just write a completely separate equation for dN3/dt
  • · Replies 17 ·
