Coupled system of differential equations
In summary, a coupled system of differential equations consists of multiple equations that are interconnected, meaning the solution of one equation depends on the solutions of the others. These systems often arise in various scientific fields, such as physics and engineering, where multiple variables interact with each other. Solutions can be analyzed using methods such as substitution, matrix techniques, and numerical simulations, and they provide insights into dynamic behaviors of the system being studied. Understanding the coupling between the equations is essential for predicting system behavior over time.
member 731016
Please see below
Please see below
For this problem,
Would it not make sense to use for ##x' = -sx - gx - ry## as a better version of ##x' = - gx - ry## since the ##sx## term connects the two DEs to form a coupled system (from what the author explains the ##sx## term represent insulin glucose transformation).
Thanks!
They are coupled because the function of one equation occurs in the equation of the other. The values ##g,r,s,d## are fixed parameters. What you wrote was ##x'=-sx-gx-ry=-\underbrace{(s+g)}_{=g'}x-ry## with simply another parameter ##g',## i.e. the same problem as the original one.
  • Love
Likes member 731016 and docnet
ChiralSuperfields said:
Homework Statement: Please see below
Relevant Equations: Please see below
from what the author explains the sx term represent insulin glucose transformation
Apart from what was already said, glucose is not turned into insulin. If the body has high glucose levels, it produces insulin, which stimulates cells to absorb glucose.
  • Love
Yes.
And though somewhat tangential, there's a probability for the body to synthesize nonessential amino acid molecules from glucose. And the amino acids then have a probability of being assembled into insulin molecules. And alternatively, amino acids that are broken down in kidneys and liver have a probability to be used for gluconeogenesis. However, the timeframe for this pathway is probably longer than the insulin-glucose interaction, and its effects are negligible on the main glucose insulin populations, hence it's completely ignored in this study.
  • Love
Likes member 731016
docnet said:
Yes.
Thank you for your replies @fresh_42, @Orodruin and @docnet!
I've done some more thinking about the problem. I think it could be a good idea to draw a compartmental model of the problem to see what is going on with the coupling of the equations since I'm still slightly confused. So drawing a compartmental model of the problem I think would look like
or
However, I'm not sure which one is correct and why. Does someone please know?
Thanks!
I'm not sure what you mean. The situation is
\begin{pmatrix}x'\\y'\end{pmatrix}=\begin{pmatrix}-g&-r\\s&-d\end{pmatrix}\cdot \begin{pmatrix}x\\y\end{pmatrix}
which you deal with in other threads, too. Furthermore, you are given the nullclines and the eigenvalues. What is the standard method according to your book in such cases?
  • Love
Likes member 731016
Thank you for your reply @fresh_42! Sorry what do you mean by standard method?
In post #5, I am trying to find the compartmental model of the problem to better understand the relationship between the terms.
Thanks!
I'm not used to this point of view, so I'm probably of little help here. Maybe these considerations help:
A=\begin{pmatrix}-g&-r\\s&-d\end{pmatrix}\Longrightarrow A^{-1}=\dfrac{1}{gd+rs}\begin{pmatrix} -d&r\\ -s&-g\end{pmatrix}
and therefore
\begin{pmatrix}x\\y\end{pmatrix}=\dfrac{1}{gd+rs}\begin{pmatrix}-dx'+ry'\\sx'-gy'\end{pmatrix}.
Now fit in your solutions for ##x'## and ##y'## and continue from there, probably by expressing ##y## as a function of ##x.##
  • Love
Likes member 731016
Here is why it is the characteristic equation.
\begin{align*}
y&=r^{-1}(-x'-gx)\\
y'&=r^{-1}(-x''-gx')\\
&=sx-dy\\
&=sx-dr^{-1}(-x'-gx)\\
-x''-gx'&=rsx+dx'+dgx\\
x''&=-(g+d)x'-(rs+dg)x\\
0&=x''-\operatorname{trace}(A)x'+\det (A)x\\
0&=\lambda^2-\operatorname{trace}(A)\lambda^1+\det (A)\lambda^0
\end{align*}
  • Love
Likes member 731016
Thank you for your replies @fresh_42 ! Do you please know whether when the solution is a stable node if rs is large and or when rs is small then origin is asymmetrically stable?
Thanks!
Thanks!
We have a trace ##-(g+d)=-3.68## and a determinant ##gd-rs=3.165## and two real eigenvalues
\lambda =\dfrac{1}{2}\left(-3.68 \pm \sqrt{(2.12)^2-4\cdot 4.3\cdot 0.21}\,\right) \in \{-2.74\ ,\ -4.62\}.
\begin{align*}
x'(t)&=0 \Longrightarrow y=-\dfrac{g}{r}\,x=-0.6744 \,x\\[6pt]
y'(t)&=0 \Longrightarrow y=\dfrac{s}{d}\,x=0.269\,x
\end{align*}
\begin{align*}
0&=x'' + 3.68x' +3.165=3.68\cdot \left(\dfrac{1}{3.68} x'' + x' + \dfrac{3.165}{3.68}\right)\\[6pt]
x(t)&=-\dfrac{1}{3.68} \cdot c_1 \cdot e^{-3.68\, t} +c_2 + \dfrac{3.165}{3.68} \cdot t\\[6pt]
x(t)&=-0.27174 \cdot c_1 \cdot e^{-3.68\, t} +c_2 + 0.86\cdot t\\[6pt]
x'(0)&=c_1-\dfrac{\det (A)}{\operatorname{trace}(A)}=c_1+\dfrac{gd-rs}{g+d}=c_1+0.86\\[6pt]
x(0)&=c_2 + \dfrac{1}{\operatorname{trace}(A)}\cdot c_1 =c_2-\dfrac{1}{g+d}\cdot c_1=c_2-\dfrac{c_1}{3.68}\\
&= c_2+\dfrac{1}{\operatorname{trace}(A)}\cdot \left(x'(0)+\dfrac{\det (A)}{\operatorname{trace}(A)}\right)
\end{align*}
This is in terms of the parameters
x(t)=-\dfrac{1}{g+d} \cdot c_1 \cdot e^{-(g+d)\,t} +c_2 + \dfrac{gd-rs}{g+d} \cdot t
If you solve the ODE for ##y(t)## in the same way, you should have all the information you can get. Now you can play around with different initial conditions, the variation of the parameters, and whatever you want to find. I would draw an ##(x,y)## coordinate system for various initial values and its vector field. The variation of parameters is probably a mess. We have ##4## parameters ##g,d,r,s## which can be either increased or decreased which are already ##16## cases, plus the fact that the eigenvalues (that also depend on the parameters) can become only one eigenvalue if the discriminant of the quadratic equation is ##0,## or become complex if the discriminant of the quadratic equation is negative.
  • Love
Likes docnet and member 731016
FAQ: Coupled system of differential equations
What is a coupled system of differential equations?
A coupled system of differential equations consists of two or more differential equations that are linked together through their variables. The solution of one equation affects the solutions of the others, making it necessary to solve them simultaneously. These systems are often used to model complex phenomena in physics, biology, and engineering where multiple interdependent processes occur.
How do you solve a coupled system of differential equations?
To solve a coupled system of differential equations, you can use several methods, such as substitution, elimination, or matrix methods. One common approach is to express the system in matrix form and then use techniques like eigenvalue analysis or numerical methods (e.g., Runge-Kutta) to find approximate solutions. In some cases, analytical solutions may be possible, but for complex systems, numerical solutions are often preferred.
What are some applications of coupled systems of differential equations?
Coupled systems of differential equations are widely used in various fields. In physics, they model interactions between particles or fields, such as in electromagnetism or fluid dynamics. In biology, they can represent population dynamics in ecosystems or the spread of diseases. In engineering, they are used in control systems and circuit analysis. These applications highlight the importance of understanding interdependent processes in real-world scenarios.
What are the challenges in solving coupled systems of differential equations?
Challenges in solving coupled systems include the complexity of the equations, which can lead to non-linear behavior and multiple equilibrium points. Additionally, the presence of strong coupling between equations can make it difficult to isolate variables and find solutions. Numerical instability and convergence issues may arise when using computational methods, requiring careful selection of algorithms and parameters to ensure accurate results.
Can coupled systems of differential equations exhibit chaotic behavior?
Yes, coupled systems of differential equations can exhibit chaotic behavior, especially when they involve non-linear interactions. Chaotic systems are sensitive to initial conditions, meaning small changes can lead to vastly different outcomes. This behavior is often analyzed using techniques from dynamical systems theory, and it can be observed in various applications, such as weather patterns, population dynamics, and financial markets.
