Coursework Chemistry Project -- Idendification of different types of polymer
In summary, Polymer is a large molecule composed of many repeated subunits. When boiling water is added, there is no chemical reaction. The pH value is not affected.
WeiLoong
35
Topic : Idendification of different types of polymer
Suggested materials : Plastic bottles or materials
Sugeested methods of analysis : Volumetric analysis, Chromatography ,pH, Solvent extration, Distillation
General purpose of project : To inculcate awareness on health and environment, To instill good moral values, To apply basic scientific skill and to apply the basic chemical principle in investigation
Polymer
This is my project in my Year-2.Polymer is a large molecule, or macromolecule, composed of many repeated subunits.
Here is my thought to coursework:
Prepare few types of plastic cup, polystrene cup.
Add water with high temperature (preffered boiling water) into the polymer cup
My problem is, is there any chemical reaction during hot water with polymer cup ? I knew that its dangerous when we drink hot water in plastic cup, but it seems nothing related to chemistry.
Is the pH value will change if hot water is in plastic cup? If not, is there any experiment that related to polymer that i can carry up ? Because the only experiment i can think is temperature affecting the polymer.
It is possible to de-polymerize some polymers, by no means all, thermally. Generally much higher T than boiling water is required. Can you be a bit more specific with your inquiry?
What a horrible project! The whole idea of, for example, plastic cups is that when you put boiling water into them nothing happens. And generally what we call 'polymers' are chemically and physically rather inert.
I did work for a few months in a polymer lab. Dissolving them was a frequent challenge. Note that these were polymers freshly made by us and maybe precipitated. So we would try things like acetone, methyl ethyl ketone, benzene, toluene, hexane, higher paraffins, 'pet ether',, that tended to be the order of increasing effectiveness.. About the last resource was 'White spirit' - I can remember boiling in white spirit under reflux for about three days some goo till a little bit of it dissolved, judged by the dirty colour. But those were polymers we made and as I say commercial ones are probably engineered to make this even more difficult. The only reason I'm telling you all this is to tell you the story of how in this lab one winter it snowed heavily and guys who cycled to work got their socks wet. Since we dried all glassware by rinsing with acetone and blowing that off with a hot fan, the guys decided they could use that technique to dry their nylon socks. However the socks dissolved into a blob on the radiator. How we did laugh.
And Anyway if and when you have dissolved your polymer material, what are you going to do with it?
I guess the only way to have any fun at all with this project, would involve making some polymers yourselves. Preferably ones you could use for something else scientific.
The only thing that comes to my mind, and that might be useful because you might encounter it later is polyacrylamide. Gels easy to make. Useful - because you can use them for things like molecular weight analysis of proteins and DNA in biochemistry. Those are polymers too. Look up a few articles on polyacrylamide gel electrophoresis (PAGE). As well as all Materials for the gel you also need a few cheap proteins which you can get from a biochemical supplier with a range of molecular masses to compare, a stain to visualize the proteins.
You have been asked to be conscious of safety etc. so for start.
http://www.ab.ust.hk/hseo/tips/ls/ls008.htm
https://web.stanford.edu/dept/EHS/prod/researchlab/lab/safety_sheets/08-136.pdf
Related to Coursework Chemistry Project -- Idendification of different types of polymer
1. What is the purpose of this coursework project?
The purpose of this coursework project is to identify and classify different types of polymers based on their physical and chemical properties. This will help in understanding the structure and behavior of polymers, which are widely used in various industries.
2. How will the identification of different types of polymers be carried out?
The identification will be done through a series of experiments and tests, including spectroscopic analysis, thermal analysis, and solubility tests. These tests will help in determining the chemical composition, molecular weight, and other characteristics of the polymers.
3. What are some common types of polymers that will be studied in this project?
Some common types of polymers that will be studied include polyethylene, polystyrene, polyvinyl chloride, and polypropylene. These are widely used in everyday products such as plastic bags, packaging materials, and household items.
4. What are the key factors that differentiate one polymer from another?
The key factors that differentiate polymers from each other include their monomer composition, molecular weight, and branching structure. Other factors such as chemical bonding, crystallinity, and thermal stability also play a role in differentiating polymers.
5. What are the potential applications of the knowledge gained from this project?
The knowledge gained from this project can be applied in various industries, including packaging, textiles, construction, and healthcare. Understanding the properties and behavior of different polymers can help in developing new and improved materials for these applications.
  • DIY Projects
  • Chemistry
  • STEM Academic Advising
9K
  • Earth Sciences
75K
