Covariant Derivative Rank 2 Contravariant Tensor
In summary: M \right)^2}$$As you can see, these are not the same as your equations. I have no idea what you have done to get such a result, so I can't tell you what is wrong with your computation. If you want to check this, I suggest you post your derivation.You are right; the stress-energy tensor that Bishal Banjara posted is the diagonal part of a more general stress-energy tensor that has all off-diagonal terms equal to zero. This more general form is the standard form for the stress-energy tensor in GR, and it is what is used in most GR textbooks. In the general form, the off-diagonal terms do not vanish, but the diagonal terms are still as given
  • #36
Bishal Banjara said:
@lbix, I have not stated that $${\phi=GM/r}$$ and the correct one is $${\phi=2GM/r}..$$
You should be aware that this is not standard notation. The standard Newtonian potential, which is what ##\phi## normally refers to, is ##- GM / r## (note both the minus sign and the absence of the factor 2). Making up your own idiosyncratic notation is generally not a good idea.
Likes Bishal Banjara
  • #37
sorry, $$\phi=GM/r$$...not $$\phi=-GM/r$$
  • #38
I know that is your notation. I am telling you that it's not standard notation. Standard notation has a minus sign in front, for good reasons.
  • #40
I took it heuristically..
  • #41
That's not a helpful response. Did you find this metric in a textbook? Or derive it from something in a textbook? What is its physical meaning supposed to be? Please give more details.
  • #42
Then you definitely need to recheck your maths.
  • #43
Ibix said:
I find it helpful to write out the sums explicitly. Thus$$\begin{eqnarray*}
0&=&\partial_aT^{ab}+\Gamma^a_{ad}T^{db}+\Gamma^b_{ad}T^{da}\\
&=&\sum_a\partial_aT^{ab}\\
&&+\sum_a\sum_d\Gamma^a_{ad}T^{db}\\
&&+\sum_a\sum_d\Gamma^b_{ad}T^{da}\end{eqnarray*}$$where there is no implied summation over repeated indices in the second line (there is in the first). There is one free index, so this us four equations, one for each ##b##. Doing the ##b=r## case, you have$$\begin{eqnarray*}
0&=&\sum_a\partial_aT^{ar}\\
&&+\sum_a\sum_d\Gamma^a_{ad}T^{dr}\\
&&+\sum_a\sum_d\Gamma^r_{ad}T^{da}\\
&=&\partial_rT^{rr}\\
&&+\sum_a\Gamma^a_{ar}T^{rr}\\
&&+\sum_a\Gamma^r_{aa}T^{aa}\end{eqnarray*}$$Again there is no implied summation. We have used the fact that ##T^{ab}=0\ \forall\ a\neq b## to drop summation terms that are obviously zero in order to go from the first line to the second.
I should note that putting the summation signs in has absolutely no effect except that I personally find it useful as a way of tracking what is being summed over and what is not.
Why can't I write the covariant derivative of $$T_{tt}$$ components as $${\nabla}_{t}T_{tt}=\partial_{t}T_{tt}-\Gamma^t_{t\gamma}T_{t\gamma}-\Gamma^t_{r\gamma}T_{t\gamma}$$ where, $$\gamma$$ runs from $$t$$ to $$\phi$$?
  • #44
You can't take the covariant derivative of a component. A component is defined with respect to a coordinate system - how could it vary covariantly?
Furthermore your expression involves summing over two lower indices, which is not legal.
  • #45
We could find numerous example following the covariant type as what I have done. My question is not exactly for that. I am expecting the difference in the result that I mentioned and what you mentioned (you could assume as what you took of contravariant type). I have mentioned the same way you expressed formerly.
  • #46
Particularly, lets take as as what you mentioned, $${\nabla}_{t}T^{tt}=\partial_{t}T^{tt}+\Gamma^t_{t\gamma}T^{t\gamma}+\Gamma^t_{r\gamma}T^{t\gamma}$$. Is this possible or not, if we extend the equation taking all summation where $$\gamma$$ runs from t to $$\phi$$ as $${\nabla}_{t}T^{tt}=\partial_{t}T^{tt}+\Gamma^t_{tt}T^{tt}+\Gamma^t_{tr}T^{tr}+\Gamma^t_{t\theta}T^{t\theta}+\Gamma^t_{t\phi}T^{t\phi}+\Gamma^t_{tt}T^{tt}+\Gamma^t_{rt}T^{tr}+\Gamma^t_{r\theta}T^{t\theta}+\Gamma^t_{r\phi}T^{t\phi}$$.?
  • #47
@Bishal Banjara you do not seem to understand what the covariant divergence is. It is a tensor. If you have a tensor ##T^{ab}##, its covariant divergence is ##\nabla_a T^{ab}##. Since this expression has one free upper index, it is a vector; the "covariant divergence" is the entire vector, the geometric object, not just one component of it.
  • #48
In the lecture of Leonardo Susskind, he writes the same form I mentioned when deriving the Christoffels from metric tensors. There are other also, Iets not make this as an issue but my core quest is other as I mentioned above.
  • #49
Reference, please?
  • #50
If you are doing wrong things, how can we not make it an issue?
I'm afraid I still don't understand what your "core quest" is, if it isn't trying to understand the proper way to compute a covariant divergence.
  • #51
after 1 hr onwards
  • #52
my core quest is this...
  • #53
after 1 hr onwards
In other words, the same material you would find in any GR textbook. As @Orodruin already pointed out way back in post #2. And as he said, that material will of course tell you how to take the covariant divergence of a tensor of any rank whatever.
"This" makes no sense. It looks like you are trying to take the covariant divergence of one component of a tensor. That is nonsense.
If that is the best you can do at explaining what your "core quest" is, we might as well close this thread. Can you do any better?
  • #54
No. This:$${\nabla}_{t}T^{tt}=\partial_{t}T^{tt}+\Gamma^t_{t\gamma}T^{t\gamma}+\Gamma^t_{r\gamma}T^{t\gamma}$$does not make sense. The general equation is $${\nabla}_{a}T^{ab}=\partial_{a}T^{ab}+\Gamma^b_{ad}T^{ad}+\Gamma^d_{ad}T^{ba}$$It is actually four equations, which you can tell because there is one free index, one that is not repeated and hence not summed over. You can specify one of the equations by setting ##b=t##, for example, in which case that one equation is $${\nabla}_{a}T^{at}=\partial_{a}T^{at}+\Gamma^t_{ad}T^{ad}+\Gamma^d_{ad}T^{ta}$$I think what you are trying to do is ask if the above means that $${\nabla}_{t}T^{tt}=\partial_{t}T^{tt}+\Gamma^t_{td}T^{ad}+\Gamma^d_{td}T^{tt}$$(where no summation is implied over ##t##). It does not, any more than 1+2+3=2+2+2 implies that 1=2, 2=2, and 3=2.
  • #55
PeterDonis said:
In other words, the same material you would find in any GR textbook. As @Orodruin already pointed out way back in post #2. And as he said, that material will of course tell you how to take the covariant divergence of a tensor of any rank whatever."This" makes no sense. It looks like you are trying to take the covariant divergence of one component of a tensor. That is nonsense.
yes, @Orodruin had already mentioned. "If that is the best you can do at explaining what your "core quest" is, we might as well close this thread. Can you do any better?" but why?
  • #56
Because, as has been said multiple times now, what you appear to be doing makes no sense. Since you are apparently unable to explain what you are doing any better, this thread is now closed. References have been given to the correct way of computing a covariant divergence.
