Covariant formulation of Coulomb's Law
In summary, the conversation discusses the discovery of a simple way to write the field of a point charge in terms of 4-vectors, using Maxwell's Equations and the concept of four-velocity. The resulting expressions for the potential and fields demonstrate the expected behavior of dropping off as 1/r and 1/r^2, respectively. It is also noted that these expressions exhibit CT symmetry and can be used to justify the idea of a positron being an electron moving backwards in time. This discovery is considered neat and new to the person sharing.
Rootboy
I was noodling about with 4-vectors and Maxwell's Equations when I took it upon myself to figure out how to write the field of a point charge in terms of 4-vectors, since I'd never seen it before (if anyone knows a book that has this I'd be happy to see it). It's actually relatively simple, which I thought was pretty cool.
So let's take a point particle with charge [tex]q[/tex] and four-velocity [tex]U^{\mu}[/tex] that passes through the origin at [tex]t = 0[/tex]. Let [tex]X^{\mu}[/tex] be the coordinate where we want to evaluate the potential [tex]\Phi^{\mu}[/tex] and fields [tex]F^{\mu\nu}[/tex]. The speed of light and the Coulomb constant are both 1. I'm using metric signature (+, -, -, -), because I like timelike vectors to have positive norms, as God intended.
So after mucking around a bit I got this:
[tex]\Phi^{\mu} = \frac{qU^{\mu}}{\sqrt{(X^{\alpha}U_{\alpha})^{2} - X^{\alpha}X_{\alpha}}}[/tex]
[tex]F^{\mu\nu} = \frac{q(X^{\mu}U^{\nu} - X^{\nu}U^{\mu})}{((X^{\alpha}U_{\alpha})^{2} - X^{\alpha}X_{\alpha})^{3/2}}[/tex]
The [tex](X^{\alpha}U_{\alpha})^{2} - X^{\alpha}X_{\alpha}[/tex] expression in the denominator of both equations works out to just [tex]r^{2}[/tex] if we're in a frame where the particle is at rest ([tex]U^{\mu} \rightarrow (1, 0, 0, 0)[/tex]), so you get that the potential drops off as [tex]1/r[/tex] and the fields as [tex]1/r^{2}[/tex] as they should. If the particle is moving that expression gives the "length contracted" [tex]r^{2}[/tex] that we expect from Special Relativity. Note that this expression is also (up to a constant and a sign) equal to the norm of the [tex]X^{\mu}U^{\nu} - X^{\nu}U^{\mu}[/tex] expression in the numerator of [tex]F^{\mu\nu}[/tex]. I'm not sure if that means anything but I thought it was kind of interesting.
Okay, so these are pretty neat and tidy formulas. But then I noticed that they kind of give you CT symmetry! If we flip the sign of the particle's charge and it's four-velocity, the potential and fields are exactly the same. So here we have a purely classical justification for the whole "a positron is an electron moving backwards in time" idea in QED. Which was new to me.
Thought this was cool and felt like sharing.
[tex]F^{\mu\nu}[/tex] for a charge moving with constant velocity is done in most EM textbooks by Lorentz transforming [tex]F^{\mu\nu}[/tex] from rest.
You have given the covariant form of these expressions, which are usually given in vector notation in terms of \phi, A, E, and B.
FAQ: Covariant formulation of Coulomb's Law
What is the covariant formulation of Coulomb's Law?
The covariant formulation of Coulomb's Law is a mathematical expression that describes the force between two electrically charged particles. It is a relativistic version of Coulomb's Law, taking into account the effects of special relativity.
How is the covariant formulation of Coulomb's Law different from the traditional formulation?
The traditional formulation of Coulomb's Law only applies to stationary charged particles, while the covariant formulation takes into account the motion of charged particles. It also uses a different mathematical approach, using tensors and four-vectors rather than scalar quantities.
Why is the covariant formulation of Coulomb's Law important in modern physics?
The covariant formulation of Coulomb's Law is important because it allows for a more accurate description of the behavior of charged particles at high speeds, where the effects of special relativity are significant. It is also a crucial component in the development of the theory of electromagnetism and its unification with the theory of relativity.
What are some applications of the covariant formulation of Coulomb's Law?
The covariant formulation of Coulomb's Law has applications in fields such as particle physics, cosmology, and astrophysics. It is used to calculate the forces between charged particles in high-energy particle collisions, the behavior of charged particles in strong electromagnetic fields, and the formation of structures in the early universe.
How is the covariant formulation of Coulomb's Law derived?
The covariant formulation of Coulomb's Law is derived from Maxwell's equations, which describe the behavior of electric and magnetic fields. By applying the principles of special relativity and using tensor calculus, the traditional formulation of Coulomb's Law can be transformed into its covariant form.
