Crash Project by 4 Days: Solve Part B | Tips & Advice
  • MHB
  • Thread starter rowdy3
  • Tags
    Project
In summary, the conversation discusses reducing the completion time of a project by 4 days and using the crash time method to determine the reduction time for each activity. However, Activity B is not on the critical path and may require a different reduction time. The suggestion is to reevaluate the critical path and determine the impact of reducing Activity B on the overall project completion time.
rowdy3
33
By how many days should each activity be reduced the project completion time by 4 days? I have all the parts right except for part B. I thought it was 2 but it's not. What I did was subtract normal time from crash time and it worked for all the problems except B. Here's a link to the table. Any ideas?
Mathematics news on Phys.org
Hi there,
It seems like you are working on a project and trying to reduce the completion time by 4 days. From what you have described, it sounds like you are using the crash time method to determine the amount of time each activity should be reduced by.
In order to accurately determine the reduction time for each activity, you will need to consider the critical path of your project. The critical path is the longest sequence of activities that must be completed in order to finish the project on time. Any delay in the critical path will result in a delay in the overall project completion time.
In your table, Activity B is not on the critical path, which means that reducing its time will not have a direct impact on the overall project completion time. Therefore, the reduction time for Activity B may be different from the other activities.
I would suggest reevaluating the critical path and determining the impact of reducing Activity B on the overall project completion time. This will help you determine the correct reduction time for Activity B.
I hope this helps. Good luck with your project!
FAQ: Crash Project by 4 Days: Solve Part B | Tips & Advice
What is the purpose of the "Crash Project by 4 Days"?
The purpose of the "Crash Project by 4 Days" is to provide a solution to Part B of the project in just 4 days, instead of the usual time frame. This is a challenging task that requires efficient and strategic planning, as well as effective problem-solving skills.
How can I effectively manage my time for the "Crash Project by 4 Days"?
To effectively manage your time for the "Crash Project by 4 Days", it is important to set clear goals and prioritize tasks. Break down the project into smaller, manageable tasks and allocate time for each task accordingly. It is also helpful to eliminate distractions and work in a focused environment.
Are there any tips for solving Part B of the project?
Some tips for solving Part B of the project include understanding the problem thoroughly, breaking it down into smaller components, and using logical reasoning to come up with a solution. It is also important to communicate with team members and seek help or advice if needed.
How can I stay motivated during the "Crash Project by 4 Days"?
To stay motivated during the "Crash Project by 4 Days", it is important to remind yourself of the end goal and the importance of completing the project within the given time frame. Take breaks when needed, and celebrate small victories along the way to keep yourself motivated.
Can I apply the skills learned from this project to other projects?
Yes, the skills learned from the "Crash Project by 4 Days" can be applied to other projects as well. This project teaches valuable lessons in time management, problem-solving, and working under pressure, which are applicable in various fields and industries.
