Crash test dummies don't always wear seat belts.
In summary: How much force is applied to a 76 kg man’s legs when he jumps off a table 1.0 m above the floor, if it takes 0.11 s for him to stop?In summary, a 76 kg man's legs would take 0.11 s to stop after he jumps off a table 1.0 m above the floor.
jillz
Crash test dummies don't always wear seat belts. If a 78 Kg dummy, in a car traveling at 53 Km/h, hits a concrete barrier, what is the force applied to the dummy?
You don't have enough information. How quickly does the dummy come to rest?
what other info should I look for?
I don't have any additional info; just the 3 other questions from the page...do they all use the same type of formula?? what other info should I look for?
1. What acceleration does Chris give his 0.48 kg Physics book, when he accidentally knocks it off a table with an impulse of 2.3 Ns?
2. A force of 3420 N is applied to a 145 g baseball. If the baseball approaches the batter at 41.3 m/s and leaves at 44.2 m/s, how long was the bat in contact with the ball?
#3: crash test dummies ?. {If a 78 kg dummy, in a car traveling at 53 Km/h, hits a concrete barrier, what is the magnitude of the force applied to the dummy?}
4. How much force is applied to a 76 kg man’s legs when he jumps off a table 1.0 m above the floor, if it takes 0.11 s for him to stop? (HINT: Remember your kinematic equations.)
Would it be this calc??
Units of Momentum and Impulse
Impulse, being the product of force and time, has units Ns. Momentum, we discovered this morning, has units of kgm/s. Since our equation states that changes in momentum are equal to the applied impulse, it follows that Ns must be equivalent to kgm/s. However, by convention, when talking about momentum we will always express our answers in units of kgm/s and when talking about impulse we will always use Ns.
Calculations using the Momentum-Impulse Theorem
Example:
What is the force applied to a 6.56 kg bowling ball that is taken from rest to a speed of 1.16 m/s in 1.31 s?
In this problem, we are given the following information:
m = 6.56 kg
vi = 0 m/s
vf = 1.16 m/s
t = 1.31 s
and need to find the force. We can rearrange F t = mv, to get
F = mv/t
Remembering that v in this case represents the change in velocity, we can substitute to get:
F = 6.56 kg • (1.16 – 0 m/s) / 1.31 s
F = 5.81 kg • m/s/s (three significant figures)
But, 1 kg ? m/s/s equals a Newton (N), our standard unit of force, so we would express our final answer as:
F = 5.81 N
Looks like these are impulse problems: [itex]I \equiv F\Delta t = \Delta (mv)[/itex]
Insufficient information provided. You're given the impulse but not the time. The same impulse can be given quickly (high acceleration) or slowly (low acceleration).
You have all the needed information.
Insufficient information provided. Again, no time is given.
FAQ: Crash test dummies don't always wear seat belts.
Why do crash test dummies not always wear seat belts?
Crash test dummies are used to simulate human bodies in car crashes and gather data on the effects of impacts. In some cases, researchers want to see the effects of not wearing a seat belt, which is why they do not always put seat belts on the dummies.
Is it safe for crash test dummies to not wear seat belts?
Crash test dummies are designed to withstand high levels of impact and are not at risk of injury like humans are. Therefore, it is safe for them to not wear seat belts during controlled crash tests.
How do researchers gather data from a crash test dummy without a seat belt?
Crash test dummies have sensors and other instruments attached to them that measure various factors such as acceleration, force, and movement during a crash. This data is then analyzed to understand the effects of not wearing a seat belt.
Are the results from crash tests with and without seat belts different?
Yes, the results from crash tests with and without seat belts are significantly different. Not wearing a seat belt can increase the risk of injury and even death in a car crash, which is why it is crucial to always wear one while driving.
Is it legal for crash test dummies to not wear seat belts?
Since crash test dummies are not human and do not have the same rights and laws as humans, it is not illegal for them to not wear seat belts during tests. However, it is important to remember that wearing a seat belt is a legal requirement for humans while driving.
