Creating 1500 watts of power in the trunk of my car
In summary, a small gas powered generator like this would work for the OP. However, the battery needed to power this device would need to be extra deep cycle, and the car's existing generator would need to be left in place.
LauraAS
Good afternoon everyone! I've exhausted my initial ideas for supporting 1500 watts of power in the trunk of my car, for intermittent use with a wall plug connection. My first thought was a simple power inverter, however, ideally I won't be running this power from my car battery. This has proven to be expensive to support the required wattage. I then considered using a portable power station - I have not been able to find one that can run at 1500w with an outlet or converter for a basic wall plug. Another alternative would be a small gas powered generator to keep in my vehicle. If anyone has any suggestions it would be greatly appreciated.
For how long are you going to use those 1500W of power each day? Does it have to be usable while you are driving? In that case a generator would not be very practical since you can't use it inside a closed car.
How much can you spend? What are you powering?
Carrying around a second IC engine and alternator seems a waste. You are already carrying an IC engine around and you could upgrade the alternator you already have. The upgrade and wiring cost will probably not be terribly more expensive than a generator.
BoB
I would hope the OP doesn't plan to run the generator in the trunk while driving the car.:smile:
In terms of simplicity, portability, efficiency at low power levels and stability of output a small inverter type generator is hard to beat for intermittent use while not in motion. As the OP said the main alternative for 1000+ watts of power while driving is a battery powered inverter with a separate deep discharge battery bank and charging system powered by the cars engine. That's not something you can just drop in the trunk and drive off with.
How about the tesla power wall? That will easily fit in the trunk and stores 7kWh.
I don't know why you need a 1.5kW supply to the trunk, but the power does not have to be generated there.
The vehicle already has a generator which extracts power from the engine.
It should not be very hard to add additional generators which are powered by the engine, or replace the existing one with a more heavy duty device.
With an older car it was pretty easy to just add a split charger circuit and a leisure deep-cycle battery in addition to the starter battery. Modern cars are just too smart for that with advanced ECU systems that monitor the SOC of the starter battery and reduce voltage to save fuel leaving the other battery flat. If the power requirement was a few hundred watts it would be easy to tie into the existing system but 1.5kW at 12Vdc is a lot of current to supply in a modern car without the ECU thinking something is wrong even if you have a completely separate charging system.
Maybe the ECU could be fooled by leaving the existing generator as it is,
and adding another generator somewhere near the engine's moving parts.
I'm thinking of some pulleys attached to the radiator pump mechanism or something like that.
They then provide the mechanical drive for the new generator.
FAQ: Creating 1500 watts of power in the trunk of my car
1. How can I create 1500 watts of power in the trunk of my car?
To create 1500 watts of power in the trunk of your car, you will need a power inverter. This device converts the DC power from your car's battery into AC power, which can then be used to power electronic devices.
2. What size power inverter do I need for 1500 watts?
You will need a power inverter with a continuous output of at least 1500 watts to create 1500 watts of power in your car's trunk. It is recommended to get a slightly larger inverter to account for any fluctuations in power usage.
3. Can I run multiple devices with 1500 watts of power in my car's trunk?
Yes, you can run multiple devices as long as their combined power usage does not exceed 1500 watts. It is important to check the power requirements of each device before using them with the power inverter.
4. Is it safe to create 1500 watts of power in my car's trunk?
As long as you use the power inverter properly and do not exceed its maximum output, it is generally safe to create 1500 watts of power in your car's trunk. However, it is important to always follow the manufacturer's instructions and take necessary safety precautions.
5. Can I use a power inverter to charge my car's battery?
No, a power inverter is designed to convert DC power into AC power for electronic devices, not to charge car batteries. It is not recommended to use a power inverter for this purpose as it could potentially damage your car's battery.
