What are the properties and equations of a 4-dimensional cube?
  • B
  • Thread starter DaMeekie
  • Tags
    Cube
In summary, the conversation discussed the understanding of dimensions and how angles are measured in different dimensional shapes. The speaker also mentioned the interesting pattern of each dimension being half of the previous one. They also discussed the challenges of accurately representing higher dimensional shapes on a 2D surface. The conversation concluded with the speaker questioning the use and meaning of these measurements and angles in higher dimensions.
DaMeekie
We all have a pretty good understanding about our three dimensions.
First starting off with 0D or a point in space = 360º. Then 1D being a line = 180º. Moving to 2D such as a square = 90º. Finally ending with 3D = 45º. It is important to state that finding these angles requires the viewer to be looking from a perfect bird's eye view to the center of each dimension.
An interesting yet very simple pattern emerges while doing this being the next dimension in this infinite series is just 1/2 the last.
With this statement we can easily find what 4D square angle would be from a perfect bird's eye view which would be 45º/2 = 22.5º.
Drawing a 4 dimensional square is a little tricky but I've managed to map one out.
I don't particularly know any use or further meaning this might hold, but any information would be wonderful.
Mathematics news on Phys.org
45º where?
There is no proper view on a cube where 45º angles would be special in any way. The simple cube sketches on paper do not represent a possible 3D view.
mfb said:
45º where?
DaMeekie said:
To note when I say a perfect bird's eye view. Which is looking directly at the focal center from a perpendicular angle. Any three dimensional crystal lattice with a perfect shape such as a cube or a sphere would appear the same in both 2 and 3 dimension
See above.
Yes it is often drawn like you did, but that is not an accurate picture. No bird can ever see a cube that way. If you see the third dimension the front cannot have 90 degree angles, which also means you cannot have two 45 degree angles there. You can have one - but that is pure coincidence then.
Likes DaMeekie
I need further iteration for that to make any sense. I hope you also realize that this isn't a solid surface this is just lines and points. Just like a lattice structure.
It is possible to model a 3 dimensional space on 2 dimensions. With proper angles and lengths to keep congruencies. I see 3D moving models on my 2D monitor screen pretty regularly. I do not think it is intelligent to disregard those models just because they are 2D virtual. The same goes with my virtual model, it keeps perfect lengths and angles. True it is not real, but I need something more if you want to convince me that I am wrong.
If you look at a square in 3 dimensions, you only see it as a square (4 sides of equal length at 90 degree angles) if your point of view is along the axis going through the center of that square. But then your view of a cube doesn't look like you drew it. If you take a point of view where the cube looks roughly like you have shown it, then the angles are 90 degrees any more. You get a parallelogram. In the extreme case, it looks like this.
So you say because a cube such as this one does not actually have 90º because it is on 2d paper?
True if you figured the actual angle is truly 120º which is not = 90º.
However when you draw out the other three lines to finish the cube as if there were no surfaces it would look like this.
Yet again the adjacent lines connecting the back of the cube cut the front cubes in half. Into 60º angles.
Now though the virtual angles on the 2d cube were 120º, but the real angles still are represented as 90º. The lines that move through the 3d space seen to cut through to the center and look to be at 60º in 2d.
Granted I didn't generate the cube properly and I can work on doing so I still believe you can accomplish the same result just half the 60 and go from there I'll respond with what one looks like soon enough to verify or falsify my hypothesis. Thank you for your insight
I'm not sure why you go from a 180° for a 1D line, to a 90° angle within a 2D square, to 45° for a cube.
For n-dimensional cubes, all 1D edges meet at the vertices, at 90° angles of each other.
The 1D line has only one edge and two vertices, so there are no angles between anything, because there is only 'one thing'. The space above and below the line do not count, since that is the 2nd dimension, and we're not supposed to be using it to measure angles yet, because we're still in the 1st dimension.
A 2D square has 4 corners where 2 lines meet, all at 90 degrees of each other
A 3D cube has 8 corners where 3 lines meet, all at 90 degrees of each other (look at the ceiling corner in your house/apartment, there's 3 lines converging)
A 4D tesseract has 16 corners where 4 lines meet, all at 90 degrees of each other
A 5D penteract has 32 corners where 5 lines meet, all at 90 degrees of each other
A 6D cube (hexeract) has 64 corners where 6 lines meet, all at 90 degrees of each other
An nD cube has 2n corners where n lines meet, all at 90 degrees of each other
Your drawings are of 3D and 4D cubes, but you had to flatten them onto a 2D sheet of paper. Well, that messes with the appearance of the angles. A 2D drawing of a 3D cube will not directly show you the perfect 90° angles that it really has, right? And, trying to flatten the already flattened 3D shadow of a 4D cube onto paper will cause even more distortion of apparent angles.
Likes mfb
In response to Philip
A straight line in a 2+ dimensional plane is an angle it's at 180º
The 90º In a square is obvious
The 45º (technically 60º from 2d standpoint) angle shows when you superimpose the back parimeter into the foreground. This is a somewhat constant when looking at the cube from a specific view point so you can make further assumptions as long as the formula States true.
Yes every angle in any further dimension will actually be 90º but that does not mean that they appear that way in smaller dimensions because of spatial warping. The lines and angles would be in very specific points due to the nature of the mathematics placed behind this and an intelligent mind should be able to formulate where those lines and angles would be. That is exactly what I'm trying to toy with to see further than what we actually think we know.
With respect to what, though? That's like saying a cube in 4D space is 180°. What exactly are you measuring?
Where are you getting the 45° from? Can you share this formula with us? How can it be 60° in 2D?
It's not a spatial warping, that deals with non-euclidean (hyperbolic, spherical) spaces. What you meant was perspective projection.
Yes, this is correct. But, it's not that difficult to define the 16 vertices of a 4D cube in R4, which is (±1, ±1, ±1, ±1), and project them onto a 3-plane, then display it on your 2D monitor. Someone already did that here:
What more is there to know about the n-cube series? The mathematics is rather simple, and well understood. We even know some of the more bizarre properties of +100D cubes, and how they differ to a 3D/4D/5D "normal" cube.
So, as stated before, an n-dimensional cube has 2n corners (vertices) while only 2n faces (which are n-1D cubes). And, we find that we get a very disproportionate number of pointy corners to flat faces. A 100D cube is almost entirely made out of its corners, and thus most of its volume is concentrated there. That's 1.2676506 * 1030 corners compared to 200 faces (99D cubes)
The distance you must travel from corner to corner is far greater than from mid-face to mid-face. If you picked up a 100D cube, you would feel most of its mass in the corners, with a mostly empty-feeling center, however that would really feel.
Also, the elements (0D corners, 1D edges, 2D faces, 3D cells, etc) can be derived with the simple formula (x+2)n , where n = dimensions of the cube. Expanding this into a polynomial, you will find that the coefficients of xn are the number of elements, per dimension n .
We can even define the surface of n-cubes with an implicit equation, which goes like:
• 1D Line :
|x| = a• 2D square :
|x-y| + |x+y| = a• 3D cube :
||x-y|+|x+y| -2z| + ||x-y|+|x+y| +2z| = a• 4D cube :
||x-y|+|x+y| - |z-w|-|z+w|| + ||x-y|+|x+y| + |z-w|+|z+w|| = a• 5D cube :
|||x-y|+|x+y| -2z| + ||x-y|+|x+y| +2z| - 2|w-v|-2|w+v|| + |||x-y|+|x+y| -2z| + ||x-y|+|x+y| +2z| + 2|w-v|+2|w+v|| = a
Likes mfb
Related to What are the properties and equations of a 4-dimensional cube?
1. How is a 4 dimensional cube different from a 3 dimensional cube?
A 4 dimensional cube, also known as a tesseract, has four dimensions (length, width, height, and depth) compared to a 3 dimensional cube which only has three dimensions (length, width, and height). This means that a 4 dimensional cube has an additional dimension that we cannot see or perceive in our three-dimensional world.
2. Can a 4 dimensional cube exist in our physical world?
While we can mathematically describe and visualize a 4 dimensional cube, it is not possible for it to exist in our physical world. Our brains and senses are limited to perceiving and understanding three dimensions, so we cannot fully comprehend a 4 dimensional shape.
3. How do you create a 4 dimensional cube?
To create a 4 dimensional cube, we can use a technique called orthogonal projection, which involves projecting a 4 dimensional shape onto a three-dimensional space. This allows us to visualize and understand the shape of a 4 dimensional cube.
4. What are some real-life applications of understanding 4 dimensional cubes?
Understanding 4 dimensional cubes can have applications in fields such as physics, computer graphics, and higher-dimensional geometry. It can also help us better understand abstract concepts and theories in mathematics.
5. Are there any other types of higher-dimensional cubes?
Yes, there are other types of higher-dimensional cubes, such as the 5 dimensional penteract and the 6 dimensional hexeract. These shapes follow the same concept of adding an additional dimension to a cube, resulting in a more complex and difficult to visualize shape.
