MHB Creating a Number Rotation: Step-by-Step Guide
  • Thread starter Thread starter ericshug
    Rotation
ericshug
Someone help me write a number rotation ,pleae.
1= filled ,2,3=every 14 seconds ,4=every 15 seconds,5=x
6,7=every 18 seconds,8=every 16 seconds,9=every 12 seconds,0=evrey 10 seconds,
roration 300 seconds total.
my bad expamle: 26783 01194 /11111 20136/ 78914 10111/ 21139 10678/41111 25031
Mathematics news on Phys.org
089 67111 41023 11018
110 67423 11110 11814
329 60711 11111 80423
111 67101 11182 34101
111 67132 08111 11111
011 67238 11011 11011
320 67811 11110 11231
116 80711 11123 10111
181 67203 11111 11108
123 67111 01111 11823
011 67111 11012 83101
110 67112 31180 11111
111 60723 18111 10111
326 87101 11111 13201
181 67111 01123 11111 , I try need fix.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
46K
