Creating a simple text parser/compiler
  • Thread starter martix
  • Tags
    Text
In summary, you need to learn about automata theory and formal CS education before you can attempt to create a compiler.
martix
168
I need to create a simple text parser that replaces {tokens} with text from a table.
The one more complicated bit is the {?text?} tag where text must be included only if the preceding AND the following tokens exist and are not empty. You could do {?text} where it looks for a non-empty neighbouring tag only on that side.
I have already bodged it based on common sense and an hour with the debugger.
What I don't know is how to approach this in a formal manner.
Like starting with a formal EBNF specification, perhaps creating the correct Abstract Syntax Tree, or however one goes about (what I assume can be classified as) creating a new language.
As you can probably guess I have no formal CS education, but I am interested in learning about this in a more structured manner (whatever 'this' is - language/compiler design?).
Technology news on Phys.org
Do you mean you have created a complete working program on your own or some working pieces?
In order to construct a compiler there are various interdisciplinary things - among various disciplines, to learn about. If you already have a decent formal knowledge on programming (with "formal" I mean knowing all the needed algorithmic stuff and good knowledge / expertise on at least one programming language) what you need is some automata theory - I strongly recommend taking a look at Stanford's online course taught by Jeff Ullman (it is free) and also a good textbook on this like this. You have to devote enough time to learn this subject. You also - this is important, must have a good knowledge on undergrad math (for more details see the prerequisites in the course I recommend for instance). Then you can go for a course on compilers. I strongly recommend this one from Stanford (it is free). Now, while you can go directly for a compilers course (for instance the one I recommend have no prerequisite knowledge) I think - according to my personal experience (I have formal CS education), that is better to know automata first and all the other "peripheral" things it requires but provided that you want to get some deeper knowledge. If this not the case then go directly to a compilers course.
I don't recommend reading just some textbooks on your own because the subjects involved are fairly complex and it is way better to learn in the interactive environment of an online course and complement all this with your own reading(s).
Likes martix and BvU
Insomuch as you can call a single function "a program", yes. Here it is. The flavour is technically PHP, but there's nothing special in there. Anyone who can read C-like code should understand what's going on easily. Would welcome improvements.
I'd like to call myself a programmer, but these days I'm really more of a code monkey. I do however have enough knowledge in plenty of C-like languages, and some understanding of algorithms - I can write you a basic DFS or construct you a tree recursively without much effort. At some point I may have been okay with undergrad math, but these days it's rusty(a recommendation here might also good). Thanks for the course suggestions; those were a large part of what I was looking for from this thread.
For Automata you must feel yourself comfortable with proofs. As for specific math topics, you must have knowledge of graphs, trees etc. and also logic. Also you may want to do some refresh / expand your knowledge on algorithms and data structures. I would recommend the excellent Stanford online course "Algorithms: Design and Analysis" taught by Tim Roughgarden.
I must note that I have personally attended all the online courses I recommend some years before on Coursera, as refreshers, so I know about their topics / quality. As for logic and proofs there are also good online courses but I think that if you have the basic knowledge you can do fine with some readings.
Sounds like you want something called a regular expression. There are lots of libraries that use various types of Regex formats, so depending on the library, you may have different syntax, but it'll certainly do what you need it to. You have Boost for C++, PCRE in PHP...
A practical manner (as opposed to a formal manner), is to use software tools that generate parsers and compilers from sets of rules given as input - rules that must be expressed in the language used by that software. Unfortunately, such software has a "steep learning curve".
Its an interesting question, what generality describes the formal structure of programs like yacc, lex, and bison.
What you describe seems to be something a stream editor like UNIX/Linux sed was designed to handle. What platform are you on and more importantly what platform does this code have to run on? I am assuming it is not an ad hoc job.
Likes newjerseyrunner
I am not clear on the problem statement.
Suppose that we have the text lookup table:
EMPTY : ""
FULL : "full"
RECURSE : "{RECURSE}"
and you have the input string:
{EMPTY} {?FULL}
Does the ?FULL check the state of the non-empty token {EMPTY} or does it match the empty "" result after replacement?
What about...
{FULL?} {?FULL}
Does that parse out as "full full" or does it parse out as "empty empty"? Or both!
On a Unix/Lenix machine, you should look at things like Yacc, awk, sed, Perl, Python. Some may be appropriate or they may be overkill.
IMO Perl is better than awk, sed, and Python for regular expressions / text manipulation.
Consider Yacc if you are really doing heavy-duty parsing of a language. Perl and Python have extensions that are 'Yacc-like'.
Perl is often already somewhere on Windows machines and the others are fairly easy to install.
I'm suggesting regular expressions as well. To learn about regular expressions and do some debugging, I like regex101.com. This is my solution to your problem (the conditions might not give the output you want, but you'll get the idea):
PHP:
<?php
$format = "This is {token1} and this is {token2} and {token3}{? text1} and {text2 ?}{token4} and {token5}{? text3 ?}{token6}.";
$tokens = [
    "token1" => "token #1",
    "token2" => "token #2",
    "token3" => "token #3",
    "token4" => "token #4",
    "token5" => "token #5",
    "token6" => "token #6"
function format($format, $tokens){
    $pattern = "/
        {([^}]+)}{\?([^}]+)\?}{([^}]+)}   (?# finds {token1}{?text?}{token2})
        |{([^}]+)(\?}){([^}]+)}           (?# finds {text?}{token})
        |{([^}]+)}({\?)([^}]+)}           (?# finds {token}{?text})
        |{([^}]+)}                        (?# finds {token})
        |[^{]+                            (?# finds anything else)
    /x";
    preg_match_all($pattern, $format, $matches);
    $result = "";
    // $matches[0] contains the entire string with token separated:
    array (size=11)
          0 => string 'This is ' (length=8)
          1 => string '{token1}' (length=8)
          2 => string ' and this is ' (length=13)
          3 => string '{token2}' (length=8)
          4 => string ' and ' (length=5)
          5 => string '{token3}{? text1}' (length=17)
          6 => string ' and ' (length=5)
          7 => string '{text2 ?}{token4}' (length=17)
          8 => string ' and ' (length=5)
          9 => string '{token5}{? text3 ?}{token6}' (length=27)
          10 => string '.' (length=1)
    foreach($matches[0] as $key => $match){
        if(substr($match, 0, 1) != "{"){ // It is not a token, write the result directly
            $result .= $match;
        else{ // It is a token
            $tags = [];    //    Will contain the info about the token tag(s).  They are stored in $matches[X][$key], where X is not 0 and $matches[X][$key] is not empty.
            foreach($matches as $key2 => $tag){
                if($key2 != 0 && $tag[$key] != ""){
                    $tags[] = $tag[$key];
            $temp = "";
            4 possibilities for $tags:
                array (size=1)
                    0 => string 'token1' (length=6)
                array (size=3)
                  0 => string 'token3' (length=6)
                  1 => string '{?' (length=2)
                  2 => string ' text1' (length=6)
                array (size=3)
                  0 => string 'text2 ' (length=6)
                  1 => string '?}' (length=2)
                  2 => string 'token4' (length=6)
                array (size=3)
                  0 => string 'token5' (length=6)
                  1 => string ' text3 ' (length=7)
                  2 => string 'token6' (length=6)
            if(count($tags) === 1){    // there is only one tag, thus no conditional text
                $temp = $tokens[$tags[0]] ?? "";
            elseif($tags[1] == "?}"){    //    left conditional text
                $temp = $tokens[$tags[2]] ?? "";
                if($temp != ""){
                    $temp = $tags[0].$temp;
            elseif($tags[1] == "{?"){    //    right conditional text
                if($temp != ""){
                    $temp .= $tags[2];
            else{    //    left and right conditional text
                $temp2 = $tokens[$tags[2]] ?? "";
                if($temp != "" && $temp2 != ""){
                    $temp = $temp.$tags[1].$temp2;
                else{ // at least one token wasn't found
                    $temp = "";
            if($temp == ""){
                $result .= "{token missing}";
            else{    //    add text replacing token(s) to result
                $result .= $temp;
    return $result;
var_dump(format($format, $tokens));
Likes FactChecker
Activity!
Starting from when last I was here:
1. Regexes. I am familiar with those. I just don't see how that would work. Given all the intricacies, it gets too hairy too fast. Actually it starts looking like parsing HTML with regex. And you know what they say about t̩̘̹̯̽̿ͦ̆̇ͮh̬̦̜͙̦͇̱͘ã̪̦̜̗̖͉͔͠t̞̱̳̲̓.
@jack action: What about multiple lookbehind or lookhead tags? Or normal text in between. Or malformed tags.
@jbriggs444: Given your set of data:
"{EMPTY} {?FULL}" = " " (if empty is empty/doesn't contain a string, we skip conditionals that rely on it)
"{FULL?} {?FULL}" = " " (no basic tags to match against)
"{FULL?} {FULL} {?FULL}" = "FULL full FULL" (matched both conditional tags, so put the text that was in there + the basic substitution tag)
2. YACC - sounds like overkill. Also above my head. The intent for this is to be an exceptionally simple syntax. Though depending on the details you could define it to do a number of more complex things(like allowing recursion).
3. sed and platform specific tools: This is mostly my own academic interest, but a production version of this would run on linux and php(which is why I started there). Also, sed is neat on general principle.
In the end I ended up doing a two-fold approach: 1. tokenize(i.e. this is a tag, this is plain text, this may look like a tag, but ended up being malformed and thus is plain text, etc.) 2. compile(process tokens). It also allows me to make recursive tags work easily too.
Regular expressions usually work fine if you do not have nested expressions to parse. If you have that, Yacc starts to be the better choice.
Because your problem ask to check if a token exists before doing anything, the solution has to be separated in two distinct components:
  1. You need to parse the text to identify the tokens;
  2. You need some logic to decide how to replace the text according to the tokens found.
The second part will be relatively the same no matter how you parse the text. The problem you asked about in this thread, is about the parser found in the first part.
You can do it by reading one character at a time, which is the safe way. The more complicated are your grammar rules (allowing escaped characters and nested tags for example) and/or if your input strings are really long, the better is this choice.
If you keep the grammar rules simple, then they can easily be identified with regexes. Since your thread title ask for a «simple text parser», it seems to fit that criterion.
For multiple lookbehind or lookahead tags, it is just a matter of adding a '+' sign here and there. The logic to replace the text properly will be done in part 2, no matter the type of parser you use.
About «normal text in between», I'm not following. There is is one tag alone or a succession of tags, anything else is «normal text in between», isn't it?
About malformed tags, well, isn't that a user problem? The grammar rules (whatever they may be), must be respected by the user. Malformed tags will be malformed with any parser. Garbage in = garbage out.
This did seem the most logical approach to me and in the end a lot of people suggested it(you included).
Normal text example is "{cond?} text {tag}". For malformed, yes, but it matters how you process it - for example "{thing}}" - how do you tokenize that. Greedily or conservatively?
And while I did say simple, both requirements and my own knowledge change, so...
I think I'll be starting that automata theory course. Maybe at some point it will warm me up to reading that terse YACC documentation. :)
Good. I was probing there to see whether it was the token name or the token value that mattered. The answer is that it is the token value.
Ahhh, so you distinguish between a "token" in braces and a conditional text string, also in braces. The syntax is similar, but the semantics are different.
Likes martix
Related to Creating a simple text parser/compiler
1. What is a text parser/compiler?
A text parser/compiler is a program that reads and analyzes text input, usually in the form of source code, and converts it into a format that can be executed by a computer. It is used to translate human-readable code into machine-readable instructions.
2. Why do we need a text parser/compiler?
A text parser/compiler is necessary for programming languages because computers can only understand binary code, which is not easily readable or writable for humans. By using a text parser/compiler, developers can write code in a more natural and efficient way.
3. What are the essential components of a text parser/compiler?
A text parser/compiler typically consists of three main components: a lexical analyzer, a syntax analyzer, and a code generator. The lexical analyzer breaks the input into tokens, the syntax analyzer checks the order and structure of the tokens, and the code generator produces the machine code.
4. What are some common features of a text parser/compiler?
Some common features of a text parser/compiler include error handling, optimization, and debugging. Error handling involves notifying the user of any syntax errors in their code. Optimization helps improve the performance of the compiled code. Debugging allows developers to identify and fix any issues with their code.
5. How do I create a simple text parser/compiler?
Creating a simple text parser/compiler involves understanding the basic principles of parsing and compiling, as well as having knowledge of a programming language. It also requires careful planning and designing of the components and algorithms needed. It is recommended to use existing tools and libraries to assist in the development process.
  • General Discussion
