Creating a solution with a pOH of 10.54
  • Thread starter jumbogala
In summary, strontium hydroxide, Sr(OH)2, falls in the category of 'slightly soluble' and won't work in theory to make a 10.54 pOH aqueous solution. However, if you use any Sr(OH)2 at all, the solution will be basic and have a pH of 3.15.
jumbogala
423
Is it possible to make an aqueous solution with strontium hydroxide, Sr(OH)2, that gives a pOH of 10.54? Explain why or why not.
[OH-] = 10-pOH
[OH-] = 10-pOH = 10-10.54 = 2.88 x 10-11 mol/L OH-
Every mole of Sr(OH)2 produces 2 moles of OH-. So the concentration of Sr(OH)2 is (2.88 x 10-11 mol/L) / 2 = 1.4 x 10-11 mol/L Sr(OH)2
My data table says Sr(OH)2 falls in the category of 'slightly soluble' (solubility less than 0.1 mol/L). Since the amount of Sr(OH)2 needed to make this solution is so tiny, it seems like this should work. Am I on the right track? I am confused about what this question is getting at.
jumbogala said:
pOH of 10.54
What is pH of this solution?
The pH is 3.46. So it's an acidic solution.
If you use any Sr(OH)2 at all, the solution should be basic. Is that what the question is getting at?
That would be my understanding.
Okay. I see that it doesn't work in theory now. However, I don't understand why it won't work in the lab. Suppose you start with pure water. Then you add a tiny, tiny amount of Sr(OH)2 to it. This should increase the [OH-] a bit. So now the pH should be slightly more than 7. It seems like this part should be possible to do in real life.
So suppose the concentration of the Sr(OH)2 solution is 1.4 x 10 -11 mol/L.
Doing the math above, we find that the pOH is 10.85, and the pH is 3.15. Which makes no sense. What's going on?
Show the math you refer to.
Okay.
pOH = -log(1.4 x 10 -11 mol/L) = 10.85
pH = 14.00 - 10.85 = 3.15
Where is OH- from water autodissociation?
So, because pure water has [OH-] of 1.0 x 10-7 mol/L, adding a small amount of strontium hydroxide to it would actually make the [OH-] go up. So the actual concentration would be something like 1.0001 x 10-7 mol/L, which would have a pOH of slightly less than 7.
So the point is, because the OH- concentration is already at 1.0 x 10-7 mol/L, you can't have an OH- concentration on the order of 10-11 (unless you add a lot of an acidic solution).
Got it. Thank you!
Related to Creating a solution with a pOH of 10.54
1. What is the significance of a pOH of 10.54?
A pOH of 10.54 indicates a basic solution with a concentration of hydroxide ions (OH-) of 0.0004 moles per liter. This means that the solution has a high pH value and is considered to be strongly basic.
2. How can a solution with a pOH of 10.54 be created?
A solution with a pOH of 10.54 can be created by dissolving a strong base, such as sodium hydroxide (NaOH) or potassium hydroxide (KOH), in water. The amount of base needed to achieve a pOH of 10.54 will depend on the volume of the solution and the strength of the base.
3. What factors can affect the pOH of a solution?
The pOH of a solution can be affected by the concentration of hydroxide ions, the temperature of the solution, and the presence of other substances that can react with OH- ions. Additionally, the pOH of a solution can change over time due to the dissociation of water molecules into H+ and OH- ions.
4. What is the relationship between pOH and pH?
pH and pOH are related by the equation pH + pOH = 14. This means that as the pOH of a solution increases, the pH decreases and vice versa. A solution with a pOH of 10.54 would have a pH of 3.46, which is considered to be strongly acidic.
5. How can the pOH of a solution be measured?
The pOH of a solution can be measured using a pH meter or pH paper. These tools measure the concentration of H+ ions in a solution, which can then be used to calculate the pOH value. Alternatively, the pOH can be calculated using the concentration of OH- ions, which can be determined through titration or other chemical reactions.
