Creating Buffers: Salt or Acid/Base Pair?
  • Thread starter Thread starter i_love_science
    Buffers Pair Salt
A buffer solution requires a conjugate acid-base pair to function effectively, but it is not strictly necessary to have both components present in the form of a salt and its conjugate acid/base. A buffer can be created using various combinations, such as starting with an acid and a salt, partially neutralizing an acid with a base, or using just a salt and adding an acid to create the desired equilibrium. The key factor is the presence of both the weak acid and its conjugate base, which can be achieved through different methods.
i_love_science
Does there have to be both a salt and the conjugate acid/base of the anion/cation to create a buffer? Or can just a salt (e.g. ammonium formate) be a buffer?
Does a buffer require a salt that contains the same conjugate base as the acid, or not necessarily?
Thanks.
Chemistry news on Phys.org
You need a conjugate pair, how you got it in the solution doesn't matter. You can start with an acid and a salt, you can start with the acid and partially neutralize it with some other base, you can start with just the salt and acidify it with some other acid.
Likes i_love_science and symbolipoint
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
