Creating terms that have the value 0
  • MHB
  • Thread starter llijnnasil
  • Tags
    Terms Value
In summary, the exercise involves finding all possible values for n that can be put between the numbers 4, 5, 6, ... , n to create a term with the value 0. The given example of 4-5-6+7=0 shows that 7 is an acceptable value for n. It is also shown that all numbers of the form 4n+3 and 4n+4 are acceptable, where n = 1,2,3, ... . Through further analysis, it is determined that these are the only possible acceptable values for n.
llijnnasil
Hey, I just found this interesting exercise and I'd like to know how to solve it.
The exercise:
Between the numbers 4, 5, 6, ... , n, you can put minus or plus signs ( - , +) to create
a term.
(n means any natural number) and (the numbers must be in order)
Which possible numbers for n can you put so that the term has the value 0 ?
I've already found a term which has the value 0, but how to find ALL the possible values for n?
example:
4-5-6+7 = 0
so in this example, the value for n is 7.
THANK YOU SO MUCH FOR HELP !
Mathematics news on Phys.org
Hi Ilijnnasil,
Welcome to MHB.
Let's say an integer $n \ge 4$ is "acceptable" if there are numbers $a_4, a_5, a_6, \dots , a_n$ where $a_i \in \{-1,1\}$ and $\sum_{i=4}^n a_i \ i = 0$. You have already shown that 7 is acceptable. Another acceptable number is 8, because $1 \cdot 4 + 1 \cdot 5 + 1 \cdot 6 - 1 \cdot 7 - 1 \cdot 8 = 0$.
If $n$ is acceptable, then $n+4$ is also acceptable, because then
$\sum_{i=4}^n a_i \ i + 1 \cdot (n+1) -1 \cdot (n+2) - 1 \cdot (n+3) + 1 \cdot (n+4) = 0$.
So we know all numbers of the form $4n+3$ and $4n+4$ are acceptable, where $n = 1,2,3, \dots $.
Can there be any other acceptable numbers? Well, notice that
$$S(n) = \sum_{i=4}^n i = \frac{n(n+1)}{2} - 6$$
If $n$ is acceptable, then the terms with +1 attached must sum to
$$\frac{1}{2} S_n = \frac{n(n+1)}{4} - 3$$
which must be an integer, so $n(n+1)$ must be a multiple of 4. Now any integer is congruent to one of 0, 1, 2, or 3 modulo 4, and we see that $n(n+1) \equiv 0 \pmod 4$ when n is 0 or 3, and $n(n+1) \equiv 2 \pmod 4$ when n is 1 or 2. So if $n$ is acceptable, we must have $n \equiv 0 \pmod 4$ or $n \equiv 3 \pmod 4$.
This rules out any numbers but $4n+3$ and $4n+4$ for $n = 1,2,3, \dots$,
so that is the complete list of acceptable numbers.
FAQ: Creating terms that have the value 0
What does it mean to create terms with a value of 0?
Creating terms with a value of 0 refers to the process of assigning a numerical value of 0 to a specific term or variable in a mathematical equation or formula. In other words, the term has no effect on the overall calculation or outcome.
Why would someone want to create terms with a value of 0?
There are several reasons why someone may want to create terms with a value of 0. One common reason is to simplify a complex equation, making it easier to solve or understand. Additionally, assigning a value of 0 to a term can help to cancel out other terms in the equation, leading to a more accurate result.
Can any term have a value of 0?
Yes, any term in a mathematical equation can have a value of 0. However, it is important to note that not all terms can be assigned a value of 0 without altering the overall equation and result. It is crucial to carefully consider the effects of assigning a value of 0 to a term before doing so.
How does creating terms with a value of 0 affect the overall calculation?
In most cases, creating terms with a value of 0 will have no effect on the overall calculation. This is because 0 has no impact on addition, subtraction, multiplication, or division. However, in some cases, creating terms with a value of 0 can help to simplify the equation and lead to a more accurate result.
Are there any limitations to creating terms with a value of 0?
While creating terms with a value of 0 can be useful in certain situations, it is important to note that there may be limitations. For example, in some equations or formulas, assigning a value of 0 to a term may lead to an undefined or impossible result. It is always important to carefully consider the effects of assigning a value of 0 to a term before doing so.
26K
