Creating XML DTDs from UML Class Diagram
In summary, to generate XML DTDs for a bus company, you would create one DTD for each class in your UML class diagram, with elements representing attributes and associations between classes.
lyd123
The question first asks to generate a UML class diagram for a bus company, which I did in the attached image. The methods arent filled in. Then the Q asks to" generate several XML DTDS, with atleast 1 attribute in each DTD, and take care to represent associations between classes"
Im familiar with creating a DTD given an XML document but in this case, what would be the layout of the dtd in this case?
Does that mean one DTD for each class?
Thanks for any help!
Technology news on Phys.org
Yes, you would create one DTD for each class in your UML class diagram. The DTD elements should represent the attributes of the class and the associations between classes. For example, you could have an element for each attribute and an element for each association. The element for an association could contain two elements, one for each end of the association.
FAQ: Creating XML DTDs from UML Class Diagram
What is a DTD?
A DTD (Document Type Definition) is a set of rules that defines the structure and elements of an XML document. It acts as a blueprint for how the data in an XML document should be organized and presented.
How can a UML class diagram be used to create an XML DTD?
A UML class diagram is a visual representation of the structure of a system or software. It can be used as a basis for creating an XML DTD by mapping the elements and relationships in the diagram to XML tags and attributes.
What are the benefits of using a UML class diagram to create an XML DTD?
Using a UML class diagram to create an XML DTD can help ensure that the structure and relationships of the data are accurately represented. It also allows for easier communication and collaboration between developers and stakeholders.
Are there any limitations to using a UML class diagram to create an XML DTD?
While a UML class diagram can provide a solid foundation for creating an XML DTD, it may not capture all of the data requirements or constraints. It is important to also consider other sources of information and validate the DTD before implementation.
Can a UML class diagram be converted into an XML DTD automatically?
While there are tools that claim to automatically generate an XML DTD from a UML class diagram, it is not always a reliable or accurate process. It is best to manually create the DTD to ensure that it meets all of the data requirements and constraints.
10K
9K
