B Creep and its effects on a material
Deformation in materials can occur under stress levels lower than the yield point due to factors like temperature and time. High temperatures reduce intermolecular attraction, allowing even low stress to cause deformation. Conversely, at low temperatures, it is expected that forces below the yield point should not lead to deformation, as intermolecular forces should dominate. However, creep can occur due to mechanisms such as diffusional processes or dislocation glide, which can enable deformation over time. Understanding these mechanisms is crucial for comprehending material behavior under varying conditions.
Aurelius120
TL;DR Summary
So I learnt that even at low temperatures materials subject to long periods of low stress would still break
What I do not get is why should a stress much lower than yield point cause deformation in a material?
If temperature is high intermolecular attraction is reduced and thus even low stress can deform things.
But if it is low
Then a force lower than yield point should be less than intermolecular attraction and should not deform it irrespective of time
Right?
Thank you
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
