Criterion for a positive integer a>1 to be a square
Math100
Prove that a positive integer ## a>1 ## is a square if and only if in the canonical form of ## a ## all the exponents of the primes are even integers.
None.
Proof:
Suppose a positive integer ## a>1 ## is a square.
Then we have ## a=b^2 ## for some ## b\in\mathbb{Z} ##,
where ## b=p_{1}^{n_{1}} p_{2}^{n_{2}} \dotsb p_{r}^{n_{r}} ##
such that each ## n_{i} ## is a positive integer and ## p_{i}'s ##
are prime for ## i=1,2,3,...,r ## with ## p_{1}<p_{2}<p_{3}< \dotsb <p_{r} ##.
Thus ## a=b^2 ##
## =(p_{1}^{n_{1}} p_{2}^{n_{2}} \dotsb p_{r}^{n_{r}})^2 ##
## =p_{1}^{2n_{1}} p_{2}^{2n_{2}} \dotsb p_{r}^{2n_{r}} ##,
which shows that all the exponents of the primes are even integers in the canonical form of ## a ##.
Conversely, suppose all the exponents of the primes are even integers in the canonical form of
## a=p_{1}^{n_{1}} p_{2}^{n_{2}} \dotsb p_{r}^{n_{r}} ##.
Then we have ## n_{i}=2k_{i} ## for some ## n_{i}, k_{i} \in\mathbb{Z} ##.
Thus ## a=p_{1}^{2k_{1}} p_{2}^{2k_{2}} \dotsb p_{r}^{2k_{r}} ##
## =(p_{1}^{k_{1}} p_{2}^{k_{2}} \dotsb p_{r}^{k_{r}})^2 ##,
which shows that a positive integer ## a>1 ## is a square.
Therefore, a positive integer ## a>1 ## is a square if and only if in the canonical form of ## a ##
That's correct.
There's a tiny flaw. You say ##a = b^2## for some ##b \in \mathbb Z##. But, you need ##b >1##.
How about if I write ## a=b^2 ## for some ## b\in\mathbb{Z} ## where ## b>1 ##?
Yes.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
