Why Does Critical Damping Reach Zero Faster Than Overdamping?
In summary, a critically damped system has two solutions that decay at the same rate, while an over-damped system has two solutions that decay at different rates. The slower decaying solution in the over-damped system will always result in a slower approach to 0 compared to the critically damped system.
MathewsMD
433
Based on the image provided, why exactly does critical damping allow the system's amplitude to reach 0 more quickly than the case of overdamping? In overdamping, isn't the term in the NEGATIVE exponential greater in absolute value? Wouldn't this cause the system to approach 0 more rapidly? That is, ## e^{-( \frac {rt}{2m} + w_d)} ## (overdamping) approaches 0 more rapidly than ## e^{- \frac {rt}{2m}} ## (critical damping) since the terms ## r, t, m, w_d ## are all positive. Could someone please clarify what's incorrect with my interpretation?
A critically damped system has two solutions which both decay with the same exponential factor while the over-damped system has two solutions which decay with one exponential factor which decays faster than and one that decays slower than that of the critically damped system. The coefficients of these solutions have to be adapted to the initial conditions and generally your solution will be a linear combination of the two solutions for each case. This means you will practically always have a component of the slower decaying solution to the over-damped system, which will therefore decay slower than the critically damped one.
Likes TheCanadian
Thank you! I was overlooking both solutions and only included one.
Related to Why Does Critical Damping Reach Zero Faster Than Overdamping?
What is the difference between critical damping and overdamping?
Critical damping and overdamping are both types of damping in a system, where damping refers to the ability of a system to resist oscillations or vibrations. The main difference between the two is the level of damping present in the system.
How do critical damping and overdamping affect the behavior of a system?
Critical damping and overdamping both dampen the oscillations or vibrations in a system, but in different ways. Critical damping results in the quickest return to equilibrium without any oscillations, while overdamping results in a slower return to equilibrium with no oscillations.
What are the main factors that determine whether a system will exhibit critical damping or overdamping?
The main factors that determine the type of damping in a system are the amount of damping present and the natural frequency of the system. If the amount of damping is just enough to counteract the natural frequency, critical damping will occur. If the amount of damping is greater than the natural frequency, overdamping will occur.
Which type of damping is preferred in most practical applications?
In most practical applications, critical damping is the preferred type of damping. This is because critical damping results in the quickest return to equilibrium without any oscillations, making the system more stable and efficient.
Can critical damping and overdamping be adjusted in a system?
Yes, the amount of damping in a system can be adjusted by changing the damping coefficient, which is a measure of the resistance to motion in the system. By adjusting the damping coefficient, the type of damping (critical or overdamping) can be changed in a system.
