Critical points of 2-Variable Function
In summary, the function f(x,y) has three critical points: (0,0), (+sqrt2, -1), and (-sqrt2, -1). These points correspond to local maxima and a saddle point, respectively.
Saladsamurai
3,020
Find local max/min, and saddle points (if any) of
[tex]f(x,y)=x^2+y^2+x^2y+4[/tex]
This should be simple, but I am having algebra-block on solving the partial derivatives to find the critical points.
[itex]f_x=2x+2xy=0[/itex] (1)
[itex]f_y=2y+x^2=0[/itex] (2)
If I multiply the second equations by -x an add it to the second and solve for x, I get
x={0,+sqrt2, -sqrt2}
But for some reason I cannot figure out how to solve equation 2 ?
Why am I retarded?
Well, for x=0 equation 2 gives: [itex]2y+(0)^2=0 \Rightarrow y=0[/itex] How about for x=+sqrt2?
I guess I don't understand this.
I want to know at what points the slope of the tangent lines is 0.
Now, I need values of x and y that satisfy both equations simultaneously. I am used to solving the equations simultaneously, not by assigning specific values to x or y.
I am not sure why that bothers me so much. But as you say:
if x=0 then eq 2 is satisfied by y=0, thus (0,0) is critical
if x=+ or - sqrt2 eq 2 is satisfied by y=-1, thus (+sqrt2, -1) and (-sqrt2, -1) are critical, yes?
Yes, you can double check that those points satisfy both equations by substituting each point into them.
FAQ: Critical points of 2-Variable Function
What is a critical point of a 2-variable function?
A critical point of a 2-variable function is a point on the function's graph where both partial derivatives are equal to zero. In other words, it is a point where the function is neither increasing nor decreasing in any direction.
How are critical points of 2-variable functions found?
To find the critical points of a 2-variable function, set both partial derivatives equal to zero and solve for the variables. This will give the coordinates of the critical point(s) on the function's graph.
What do critical points tell us about a 2-variable function?
Critical points can indicate the location of local extrema (maximum or minimum points) on the function's graph. They can also help us determine the behavior of the function in different directions.
Can a 2-variable function have more than one critical point?
Yes, a 2-variable function can have multiple critical points. This means that there can be more than one point on the function's graph where both partial derivatives are equal to zero.
How are critical points related to the graph of a 2-variable function?
Critical points are points on the graph of a 2-variable function where the function's tangent plane is horizontal. This means that at these points, the function is neither increasing nor decreasing in any direction.
