Critical points of a multivariable function (wave equation)
In summary, the discussion was about checking the understanding of a problem involving a multivariable function and its critical points. The function in question was f(x,t)=sin(x-v*t), and it was determined that the critical points are on the lines x = vt + pi/2 +/- n*pi, and there are no isolated points where the gradient is 0. The conversation also touched on the definition of isolated points and the graph of the function.
Poetria
267
42
There is a function ##f(x,y)= sin(x-v*t)## for v>0
Which of the following best describes the critical points of the function?
##f_x(x,t) = cos(x-v*t)##
##f_t(x,t) = -v*cos(x-v*t)##
I would like to check my understanding of this problem.
There are the following possibilities:
a. Isolated points where the gradient is 0.
b. The level curves of height 0
c. The level curves of height 1.
d. The level curves of height -1.
e. None of the above.
I would choose a, c, d.
Where sin(x-v*t)=1, cos(x-v*t)=0 (the gradient is 0). Is there a pitfall here?
Poetria said:
Homework Statement:: There is a function ##f(x,y)= sin(x-v*t)## for v>0
Relevant Equations:: ##f_x(x,t) = cos(x-v*t)##
Hi. You haven't explained how/why you made your choices (a, c and d).
Also you have a small typo': ##f(x,y)= sin(x-v*t)## should be ##f(x,t)= sin(x-v*t)##. (However don't let the use of 't' cause any confusion. - it's just a variable name. The maths is the same as for ##f(x,y)= sin(x-v*y)##).
Likes THAUROS and Poetria
Steve4Physics said:
Hi. You haven't explained how/why you made you choices (a, c and d).
Oh, of course, f(x,t). I can't edit the post. :(
My reasoning is as follows:
"A critical point of a multivariable function is a point where the partial derivatives of first order of this function are equal to zero."
If sin(x-v*t)=1 (i.e. ##x-v*t= \frac {\pi} {2}+n*\pi)##), then ##f_x=cos(x-v*t)=0##
If sin(x-v*t)=-1 (i.e. ##x-v*t=\frac {-\pi} {2} - n*\pi##), then ##f_x= cos(x-v*t)=0##
Similarly for ##f_t(x,t)=-v*cos(x-v*t)##
The gradient is a derivative, therefore if a gradient is zero at a given point, this point is a critical one.
Likes THAUROS
Your answers were:
I think you have justified c and d - though you haven’t made the logic explicit. I would have been tempted to have added something like this:
##f_x## and ##f_y## are both zero when ##x – vt = \frac {\pi}{2}±n\pi## ##(n = 0, 1, 2, ...)##
E.g. for n = 0 this give ##x = vt + \frac {\pi}{2}## which is a straight line in the x-t plane (corresponding to f(x, t)=1).
But, more importantly, you haven’t justified your choice ‘a’.’ Can you?
Well, I don't think I understand the concept 'isolated point' well. I have found a definition in the calculus book, p. 227: https://books.google.pl/books?id=1dQ7LgPsDzYC&pg=PA230&dq=isolate+points+gradient+multivariable&hl=pl&sa=X&ved=2ahUKEwiB-a6v_LryAhXTuKQKHa_kBhoQ6AEwAHoECAkQAg#v=snippet&q=isolated points &f=false
"If there is an open ball B centered at ##x_0## and contained in O with the property that for all ##x \in B, x \neq x_0##, x is not a critical point of f. That is ##x_0## is the only critical point of f in B."
But it is possible to construct an open ball with more critical points in this case. Am I right?
I had to check the definition for an open ball - https://mathworld.wolfram.com/OpenBall.html
So my choice of a isn't correct.
Likes THAUROS and Delta2
Agreed - choice 'a' is incorrect.
But don't get tied-up or distracted by the term 'isolated point'. It’s not meant to be that complicated. A common-sense interpretation of ‘isolated point’ is perfectly adequate here (I say that as a non-mathematician!)
___________
Diversion/Example
Consider a domain consisting of the line ##y = x+ 2## and the point (1,1).
Any point, P, on the line is not isolated. For example the point (1, 3) is not isolated. That’s because P has immediate neighbouring points – because the line is a continuum.
But the point Q(1,1) is not on the line. Q is not connected to the line. Q has no immediate neighbouring points. Q is a single unconnected dot on the xy plane. We say Q is an isolated point;
Diversion ends (and my apologies to any mathematicians reading this).
__________
Thy only way to get ##f_x=0## and ##f_y= 0## is to make ##cos(x-vt) = 0##. This only occurs when ##x – vt = \frac {\pi}{2}±n\pi##
Each value of n gives a unique line ## x = vt + \frac {\pi}{2}±n\pi##. So ##f_x=0## and ##f_y= 0## at all points on every line and nowhere else.
Therefore there are no isolated points where ##f_x=0## and ##f_y= 0##.
___________
To get a better intuition, see what the function ##f(x, t)=sin(x – vt)## looks like. I’ve used ‘y’ rather than ‘t’ and set v = 4 for illustration purposes:
https://www.wolframalpha.com/input/?i=3d+plot+sin(x-4y)
Of course this is just one region of the graph – the graph extends from -∞ to +∞ in both x and t axes.
Every point on a crest or trough is a critical point.
  • Love
Likes THAUROS, Poetria and Delta2
Wow, that's very lucid. :) Thank you very much. :)
Likes THAUROS and Steve4Physics
Yes, but the test in the definition is whether you can find an open ball that does not contain any other critical points. That there are some open balls that do is irrelevant.
Likes Poetria
Oh, ok. I got it. :) Many thanks.
FAQ: Critical points of a multivariable function (wave equation)
What is a critical point of a multivariable function?
A critical point of a multivariable function is a point where the partial derivatives of the function are equal to zero. This means that the slope of the function in all directions is zero at that point.
How do you find critical points of a multivariable function?
To find critical points of a multivariable function, you must first take the partial derivatives of the function with respect to each variable. Then, set each partial derivative equal to zero and solve the resulting system of equations to find the critical points.
What is the significance of critical points in multivariable functions?
Critical points are significant because they represent potential maximum, minimum, or saddle points of the function. They can also help determine the behavior of the function in different regions of the input space.
How do critical points relate to the wave equation?
In the context of the wave equation, critical points represent locations where the wave is either stationary or changing direction. This can be useful in understanding the behavior of waves in different environments.
Can a multivariable function have more than one critical point?
Yes, a multivariable function can have multiple critical points. In fact, most functions will have multiple critical points, especially if they are complex or have a large number of variables.
