Peter Alexander
- 26
- 3
1. The problem statement, all variables, and given/known data
Find and categorize extremes of the following function: $$F(y)=\int_{y}^{y^{2}}\frac{1}{\ln^{2}x}dx$$ for ##y>1##.
$$\frac{d}{dx}\int_{a}^{b}f(x,y)dy=\int_{a}^{b}\frac{\partial}{\partial x}\left(f(x,y)\right)dy$$ and $$\frac{d}{dy}\int_{\alpha(y)}^{\beta(y)}f(x,y)dx=\int_{\alpha(y)}^{\beta(y)}\frac{\partial f(x,y)}{\partial y}dx+\beta'(y)\cdot f\left(\beta(y),y\right)-\alpha'(y)\cdot f\left(\alpha(y),y\right)
Applying the formula for derivative of a parameter dependent integral gives the following result:
\frac{d}{dy}\int_{y}^{y^{2}}\frac{1}{\ln^{2}x}dx=\int_{y}^{y^{2}}\frac{\partial}{\partial y}\left(\frac{1}{\ln^{2}x}\right)dx=0
but since boundaries of integration are parameter dependent, the other equation should be implemented
or in this case
\frac{d}{dy}\int_{y}^{y^{2}}\frac{1}{\ln^{2}x}dx=0+\frac{2y}{\ln^{2}\left(y^{2}\right)}-\frac{y}{\ln^{2}\left(y\right)}=0
This is true if, and only if, ##y=0##.
I've solved the problem up to this point, hitting a brick wall. Because no other solution besides ##y=0## is available, yet task explicitly says that ##y\text{ must be }>0##, either something is wrong with my computation or this problem is unsolvable.
PS: this is my first post, so if you have any comment on the styling and/or content, please let me know so I can improve my questions in the future. Also, if anyone is willing to help me, I'd like to thank you in advance.
or in this case
